need help 06 trailblazer actuator
ldog
10
have the famous clicking noise third row ext tb 06 need info on how to remove the panel i have searched hi and low for pics or a video and come up blank just dont want to break nothing trying to figure it out on my own need help any one
ldog
10
i know this is a actuator problem through research its a very common problem but no one has posted any pics or video i can find on how to correctly fix it i think i will be the first from what i can tell
ldog
10
ya this noise is driving me nuts but dont wanna break anything while trying to fix it lol
I have never completely removed the panel but enough to access the rear HVAC unit. It`s a fairly simple affair, a few screws and undoing it from under another trim piece and you can move it out of the way enough to get to it.
If you wait long enough, the noise will eventually go away when the gears get completely worn away :biggrin:
ldog
10
ok do i need to remove the top panels aswell there is two one rear and one on the door also do i need to remove one of the third row seats it looks like i might have to
Mounce
13,667
Tuscaloosa, AL
RayGumm said:
Dude. Harsh. Hurts, bro.. the feels.
Patience is a virtue. It's pretty late for most of the country. Cool thine jets.
:iagree:
But yeah, wait it out man, it's a little early to decide that there is no one here to help you. I assure you that this is the best place to get help. Btw, Welcome to the Nation!!! :tiphat:
Welcome! A beautiful 5AM on the west coast.
There is an Article on this site, showing the process. Can't explain why it didn't show up in a search.I used the magic Google phrase "trailblazer ext removing rear hvac panel site:gmtnation.com"
http://gmtnation.com/forums/topic/2079-rear-hvac-blower-control-module-replacement/
I don't have an EXT, but from reading things, I seem to remember the seat belt bolt are about the only fasteners that aren't simple pull-off clips. The seat belt bolt require Torx drivers, so if you don't have a good set, it's a good excuse to buy them now.
I didn't remove the upper panel to do this I'm too lazy but it works
Yeah, I do disconnect once or twice a week to sleep.
Reactions: BHAMER
ldog
10
Thanks for the help on this the only bolts were the seatbelt fasteners then the rest was clips except 5 phillips screws around the rear area 3 bottom 2 top orileys had the part thats fine now i have other issues gonna look for threads on the steering position sensor and low oil pressure sensor where they are and how to remove and replace i was agervated at this truc the last time i was on searched and searched for help ocd doesnt help either lol only had this truck 3 weeks
ldog said:
looks like no help here either
Could be because you posted on the appearance section...
DocBrown
501
Watch out when you pull the actuator off. I broke one of the shafts on mine. They are just flimsly plastic. Fortunatly there was just enough of the shaft left for the actuator to still work. A lot of members have broken them clean off.
Reactions: jpimp
domkan
