It was a fun filled weekend of working on the 97x and my GF's Rendezvous.
In what was supposed to have been a Friday night working on her bearing (which died the same day mine did) turned into a two day adventure. Her alternator died as she pulled into the driveway, thank god!
I can't believe that the diff cover seal was almost $30 more than the trailblazer's seal. Anyway, I attached a few pics. Of of the diff before I wiped all the crap off of the gears and after. Is that amount of black gunk normal? It makes me think that the fluid was never changed and I have about 160,000 miles on it. The oil that came out was pure black, NOT dark brown. Is it okay to spray any cleaners in the diff to clean some of that out? I was worried I would damage some seal or something in there.
I did replace the seals and bearing on both sides, I didn't even know they were leaking. It had to have been a slow leak as it was not wet, but there was definitely black "soot" around the seals on both sides. The clicking over bumps is gone though, so that did in fact fix the issue!
I noticed that there was a second bearing behind the first one. Should I have replaced that one as well? Does that one normally go bad? I was going to replace it, but I couldn't see the back side of it and left it alone. I wasn't sure how to remove it, without being able to get a puller behind it. It could have just been so black from grime that I couldn't see it. I plan on changing that oil again in the summer because it was so black.
