Exhaust Pipe Diameter After Resonator
Jayman
96
Hello everyone!
I want to install a tip on my 07 Denali. It has factory exhaust with the resonator installed. All I want to do is remove part of the curved tailpipe after the resonator and add a tip. For this I need the correct diameter of this short pipe so that I can order the correct tip.
It appears to be smaller than the 2.75" pipe that runs from the cats before the resonator.IMG_20171022_2341389.jpg
Thanks all
Sir ffeJ
543
Not sure myself but you could always wrap a piece of wire around it then measure the wire.
Jayman
96
Appreciate the suggestion. Just figured with so many who have likely done exhaust work that someone would know off the cuff ☺
Not sure on the resonator as most cut it off to add a tip. I know its 2.75 back to the axle at least.
Why not just use a dial caliper?
The 5.3 might have a bigger pipe than the 4.2, which is normally 2.75.
Personally, I'd chop off the resonator and put a straight pipe with a tip. Thrash the can!
Jayman
96
LOL if I had the tool...
I believe the 5.3L is also 2.75" as I mentioned already. I'll be installing a muffler and I want to be sure there is no drone whatsoever. Hence why the resonator stays, to each his own I guess.
Jayman
96
Just an update guys, the pipe after the resonator is confirmed to be the same size as before the resonator at 2.75".
Appreciate your feedback everyone.
kraymates
