ok guys , i think i fix it ' engine now is running , i keep it running for 30 minutes, i switch it off many times to check , scan tools now can communicate with the car , PRND321 now working
i didn't try to make drive test , i was tired , long day diagnosing ,
i will write extended post for any one how will get similar problem ,,
the ignition switch was fine and i tested it with help up from our heroes
@Mooseman @MRRSM here and another topics i read ... and this post by roadie
Hello, can anyone tell me what wire are hot that come out of ignition switch. Start, Run Acc. Replace CPM still no start
gmtnation.com
the damaged wires shown up in post fixed but wasn't the reason for no crank or no prnd321
but i have more better situation and feeling also ,
the main problem was the grounding point in the engine - driver side between the stater and coolant outlet
i describe the location with red circle in this image i attached
how i know ?
i run the ignition to start position and start checking again and again, when start inspecting the pcm wiring harness and see the cracked wires, i noticed the pcm will have power and make that ticking sound when i start jiggling the wiring harness and i noticed a fast ticking sound from top of the engine - not throttle - and that ticking sound go way when i shake or wiggle the harness , so i start looking for broken wire , until i found that the grounding is rusty and loosing connection
i mad a YouTube video for that . here its
then after that i have prnd working , no "check brakes" or check abs on dtc.
Bit I still cant crank . so I test the fuses again andvi dound 2 blown fuses. Onewas foe the pcm and the other is accessories.
No the engine run and crank good . obd connection ..
Bit o still have some troubles. The rpm was funny and playing arround. Figured its thw white wire in the pcm harness. Ok its better but not fixed because I played with the cluster a bit when I removed the cluster unit. And think it need replaced or calibrated.
Alo I still have the ticking sound in doors panels and the lift gate and losing the power in them and when I lock the doors its keep locking for 4/5 times .
I glad that th enginevis running. I hope it will still. I jist replaced the engine with used one before 2 months and warranty finished.
I will keep updating here and see the next days if it will stay good.
My advice for who have similar problem;
1- start with basic /simple things , dont jump up"like i did" to the big things like replacing pcm or dashboard or bcm or lgm or PRND321 switch or any thing else until you have done the simple things
2- keep testing the fuses again and again after doing any fix
Soo many thanks for this forum and especially for Heroes @Mooseman @MRRSM words is not enough… for helping here and there helpful answer's arround the forum . also for roadie and my03lt
