Engine no acceleration
7,787
Yes. Please ...Watch the Brief Video from ScannerDanner in Post #155 .
The PCM will continue reading from the Old LTFT History as remaining High from what has previously been stored in the Computer and begin to use the newly setting Negative STFT Levels to gradually counter-balance the elevated LTFT while it is in the process of "Re-learning" what the Nominal Fuel/Air Mixtures should become while Idling and through periods of Acceleration.
If you follow ScannerDanner's suggestions for how to Test this, after borrowing a Friend to do the Driving with YOU in the Passenger Seat, start out on an Empty, Safe Street from a Stopped position and Go to Wide Open Throttle in First Gear...
(Go Carefully Though... Tell the Driver to Avoid Over-Revving The Engine).
You will want to observe your Live Scanner for LTFT AND STFT as well as BOTH O2 Sensors. You should be looking for your Upstream O2 Sensor to STAY RICH while also watching that your Fuel Injector Duty Cycle increasingly ADDS FUEL. If the Upstream O2 Sensor remains RICH for that entire brief period of WOT... then you will have properly cleaned and have a working MAF Sensor again and the problem of the P0171 should then remain resolved.
Uncleenvoy
545
Ny
Just watched the vid..the end is what i was seeing on my live data..high negative shrt term ft..i cleared the codes..nothing pending now after i drove about 4 miles..i did have a p0017 and p0171 pending last night along with the p0171 that triggered the CEL ..gonna do the highway drive later tonight
All the posts relating to torque wrenches have been moved here since it went way off-topic. Please keep those discussions in that thread.
Reactions: mrrsm and gmcman
Uncleenvoy
545
Ny
@JayArr yes sir..gave them the second key.and they've been driving it..no complaints yet..its a nieghbors girlfriend that bought it so i see it almost everyday..i was gonna buy this one today..went and looked at it on tuesday..he wanted 1200 got him down to 1000..told him ill pick it up today cause i was gonna be busy with my business yesterday..took the money out the bank and everything..but an opportunity popped up yesterday thats gonna boost my business and its gonna require all the money and time i got..so unfortunately had to call him tell him i couldnt do it..he was cool about it..it has a slipping transmission and p0128 but with no check engine light..so i was thinking easy fix and sell..still available if anybody wants it..its in long island Ny
Reactions: Mooseman and gmcman
memoremix
