ELM327 & Class 2 Serial Data
Well the plan is to do it with an arduino so I'd like to use that. Would it be ok to plug the arduino digital pin into the obd port on my truck or would that mess something up. Its a 2000 s10 LS. The coolant temp and fuel level and probably gear indicator are all that's controlled over serial but they all come from the ecu I would assume but I want to replicate the data the ecu sends to the cluster not what goes into the ecu. I don't even know if that's the same data line that goes to the DLC, I'm pretty sure it's not.
You cannot simply connect an Arduino to a serial data bus and have it do anything. It requires more hardware and software for the Arduino.
This is my own Arduino project to connect to a J1850VPW bus...
The Arduino Nano is the small board attached to the larger board.
The code I put together to run it is several hundred lines long.
There is another thread here on this website titled Arduino Chat that discusses this sort of thing.
I would say "in that case I'll only have tach and speed" but even the gear selector is done over serial. I'm lazy and mostly deal in hardware and the cluster i bought will never be used for anything other than video games again so I'll probably just tear the cluster apart, take all the chips off the board and wire all the gauges and lights up to only an arduino so I'll have full control and won't have to deal with a 25 year old barely documented data standard.
im already trying to learn LIN messages for a tesla because i bought a tesla steering wheel for a different project that failed so im using that for the wheel of the sim and i cant even figure LIN out. if i just tear into the chevy cluster and make it simple then its one less data line to not deal with.
I just got my cluster in. It does work but my theory of just running all the gauges and LEDs with an arduino instead of serial might not work. I didn't realise that these gauges are servo motors not whatever is in the older ones and this board is alot more complex than the older ones. I really don't want to have to deal with serial data though, any idea what would be easier?
@TJBaker57
I've been trying to map out a few commands my 2006 Avalanche uses and this thread has been of great assistance. That spreadsheet is awesome for quickly finding what is talking to what. I'm using ELM327 dongles (both a bluetooth one and a USB one) to log messages on the Class 2 network and I have successfully sent a few messages found here and elsewhere, such as making the car chime, door lock/unlock, gauge cluster light tests and sweeps, etc so I know my setup works.
However, what I seem to be stuck on is what exact header to set when trying to forge and send a message to the car that I've previously logged. One example, the OnStar system is capable of displaying the phone number you have verbally told it to dial on the DIC before it tries to make a connection. I have recorded a session with those message being sent (even ASCII decoded the data hex bytes to confirm it matches the number that was displayed). But while trying to re-play these OnStar to DIC messages (via ELM327 serial console), nothing is happening, and I suspect its because I'm not setting the "AT SH xx yy zz" header correctly.
Any advice on how to calculate the correct header to use while using your spreadsheet to reference and decode each raw message?
My spreadsheets are a mess ;) I don't even know what ones are where and how many times I've copied and altered them to suit the moments needs !!
I know I shared one or more here, but I really didn't think anyone used them.
That's a very good start right there.
I once read somewhere a fellow had done this for fun, sending a message to the DIC.
I usually will begin such a task by just mimicking the message seen in the recorded session. Is this what you have tried?
Go ahead and post up some of the recorded session here if you can.
I believe this is all of the relevant section from the raw capture. Address 97 is the OnStar module.
Code:
13:19:50.976 8A EA 97 B1 01 97 12 17 00 00 33
13:19:50.976 08 FF 58 03 E8
13:19:50.984 8A EB 60 B1 01 97 12 17 00 00 82
13:19:50.999 8A EB 97 B2 01 12 20 20 20 20 20 0B
13:19:51.008 8B EA 60 72 01 54
13:19:51.039 8A EB 97 32 01 12 20 20 20 20 20 B7
13:19:51.050 8B EA 60 72 01 54
13:19:51.055 28 FF 40 06 07 0B 0B 83
13:19:51.086 8A EB 97 B2 01 12 20 31 32 38 33 AC
13:19:51.087 8B EA 60 72 01 54
13:19:51.125 8A EB 97 32 01 12 34 35 36 37 38 6F
13:19:51.125 8B EA 60 72 01 54
13:19:51.149 8A EB 97 B2 01 12 39 30 04 20 20 EB
13:19:51.157 8B EA 60 72 01 54
13:19:51.166 88 25 29 07 00 97
13:19:51.169 8A EB 60 B3 01 97 12 01 38
13:19:51.263 08 FF 1A 03 9A
13:19:51.384 08 FF 98 03 CB
13:19:51.429 08 FF 80 03 25
13:19:51.658 88 25 29 07 00 97
13:19:51.768 8A EB 60 B3 01 97 12 06 6B
Reactions: TJBaker57
Code:
I just may have to have a look at my own 2 Onstar vehicles. Both are the older defunct systems I believe. Never had a reason to fool with them before. Will need to peek into the owners manual for instructions !
Mines defunct as well, plus I took away it's antenna. To get it to show messages on the DIC, hit the call button (either on the mirror or the steering wheel), say "call number", it will respond, then you can speak a phone number. It will confirm the number by displaying it on the DIC.
My other goal of figuring out these Class 2 messages is to spoof the XM radio module. I patched into the analog audio signals between the XM module and the head unit to setup an Aux input, but have to leave the XM module powered up and connected to the Class 2 network, otherwise the head unit disables the XM input. I want to spoof the init and heartbeat messages to keep the XM input available (while ripping out the XM module) and also make use of the Artist and Track message fields to display other info. I think I've captured all of that, just have to figure out how to calculate what headers to set to send those messages.
But we'll start with the DIC messages and work from there :) Thanks!
I've read this thread twice and I still don't know how to record and send messages on the class 2 bus. The closest I got was this. I typed "atma", hit enter, and when nothing happened for several seconds, I turned the ignition switch off and suddenly the window was full of those '88 6f 10 01 10 00 60' interspersed with the occasional 'cc fe 10 60 8b'.
I installed the recommended "Serial Bluetooth Terminal" app but it almost immediately disconnects after I hit connect. My guess is since I'm doing this in a 1999 Saturn SL2, which I believe only has the IPC and PCM on the DLC pin #2 network, there's nothing keeping the network alive. The RKE module is connected to the PCM, but the circuit diagrams imply that it's simply connected to an internal relay that opens the connection to ground whenever the engine is running and the VSS says the vehicle is moving more than 8 MPH (or was it 3).
So yeah, to be clear, I'm asking if there's a video or guide somewhere showing how I can interact with the bus using a Bluetooth elm327 dongle. Specifically, how to record messages and eventually experiment with sending. I already have the 1999 versions SAE J2178 and understand how messages are coded.
Welcome to the forum! Always happy to see more folks learning and using the power of OBD2! :smile:
I can't point to a video or a tutorial offhand, but as you've seen in this thread, there are several folks here who are very familiar with OBD2.
But you were able to send the "ATMA" command, so it must have worked at some point, right?
Your 1999 Saturn's PCM definitely is connected to the DLC (16-pin connector), on pin #2, so it should speak the VPW protocol (protocol #2 in the ELM327 world): CHARM website: 1999 Saturn DLC wiring diagram
So, my quick 'n' dirty recommendation is to do this, to see if you can communicate with the PCM, because if you can't get that working, there's no point going any further, IMHO.
Code:
>ATZ
ELM327 v1.3a
>ATL1
OK
>ATTP 2
OK
>ATDP
SAE J1850 VPW
>ATH1
OK
>0100
48 6B 10 41 00 BE 3F B8 11 75
Your adapter's reply to the 'ATZ' command might be different and your vehicle's reply to the '0100' command will almost certainly be different, but you should get a reasonable reply (not "NO DATA") to the '0100' command, which (assuming that your adapter powers up with OBD2 header bytes set for functional addressing using what's known as "Legislated Diagnostics", which is almost a certainty) is simply a command that asks any supporting node to report their Mode $01 PID "capabilities". It's an innocent (safe) command that the PCM is required to support.
If that works, you're off to the races. If not, let us know and we'll help figure it out.
Good luck! The journey to OBD2 nirvana is long, but rewarding. :smile:
One of my neutral attributes is whenever something doesn't work they way I thought it would, my response is to try to get more information rather than just throwing a million monkeys at a keyboard and hoping I happen to be watching when the right thing finally does happen at random. Situations like this is why I consider it neutral rather than positive, since I should have tried using the other commands...
Anyway, this is what happened when I tried again just now. There was a severe lag between when I hit send and something shows up on the terminal. It still apparently freezes after "atma" and this time there was about a 10 second delay after I took the key out and the window filling up, so it was probably a coincidence. Since I can't copy and paste from that app and the Samsung multipage screenshot isn't working, I have no idea how many lines there is.
With the "Serial Bluetooth Terminal" app, I was assuming it rather instantly disconnects because unlike the "car scanner" app, it has no idea what it is connected to and maybe the elm327 expects periodic "pings" from whatever device is connected to it? The most low level networkish thing I've done is write an IRC chat bot. With that, the server sends a PING message every minute or so and if it doesn't get a PONG reply, the connection is lost. I would also expect to have to configure it to display the data as hex and not sure how the checksum is calculated or when I would need to do so.
I guess for now, I'm going to try to find another app with a functional "terminal". Thanks for the swift and non-hostile reply!
That's because "ATMA" is unleashing a "torrent" of traffic on your poor little adapter! I'll humbly recommend that you initially stick to commands that provoke a single reply from the vehicle/adapter, not one which will overwhelm even some of the most capable of adapters. This, IMHO, is a better way to learn how OBD2 communications work.
If you insist on testing with "ATMA" (no judgment on my part, that's certainly an interesting, if overwhelming, experiment :)), then read up in the ELM327 datasheet on how to limit the traffic, which will make your adapter stop screaming in pain from the "flood"! ;)
Some adapters are designed to go to sleep after some duration with no traffic. In fact, some vehicle nodes are the same way. If your adapter and/or your vehicle's nodes are like that, then a "ping" (typically something innocent like "ATRV" to query the adapter's voltage or even my aforementioned "0100" command) can be warranted. But that's pretty rare, in my experience. Nevertheless, you'll see a lot of OBD2 software do these sorts of "pings".
I don't see that there's anything obviously wrong with your Bluetooth serial app. Both before and after you connect to the vehicle, the adapter does nothing until you tell it to.
@mr_infamous
Tell us SPECIFICALLY what OBD2 adapter you have there. Like share a link to the item??
There are a lot of cheaply tossed together items out there and I ran through 3 or 4 different devices before discovering the Veepeak units.
My 1st few adapters would drop the connection repeatedly making them nearly useless.
None of my 8 or 9 Veepeak units exhibit such behaviour.
No. Serial Bluetooth Terminal is a very basic simple interface. It doesn't expect to see anything, and it doesn't do anything you haven't told it to do.
So if the connection to the bluetooth dongle drops out, that is a fault of the bluetooth device or the android device.
Car Scanner does keep talking to the bluetooth device AND the PCM whenever it is connected. This can help maintain a connection with a low quality bluetooth device.
However, Car Scanners' serial terminal is not meant for any heavy lifting. So throwing an ATMA instruction at it is bound to cause trouble.
I just looked at the current version of Car Scanners terminal. It is definitely whacky right now so I would steer clear of it.
ATMA means you want the bluetooth adapter to put onscreen absolutely every message that is on the vehicle data network. Everything. And it will keep doing that until you press the "send" again. At that point it will report "STOPPED".
If you try to send something different while the ATMA instruction is still printing out all messages to the screen, it will not work.
You must conclude the ATMA instruction by pressing send again BEFORE sending anything else.
The instruction @AmpOverload gave you "0100" is a standard query to your vehicle requesting which of the standard OBD PIDs between $01 and $20 does your vehicle support? The response you received contains that information. It is coded and needs to be decoded to see what's what.
Wikipedia and others can provide the details of how that is done. I have a spreadsheet made up for such things. Where column C has a green background with a 1 in it are the standard PIDs your vehicle supports.
See Column C, row 17? The 1 there indicates your vehicle supports the Mode $01, PID $05 which is "engine coolant temperature".
If instead of sending "0100" you follow the same steps and send "0105" you will receive a response which contains your engine coolant temperature. It will be the 6th byte of the message, given as celcius, in hexadecimal format, most likely with a +40 offset. So you take the hexadecimal value, convert that to decimal, then subtract 40 and that's your engine coolant temperature in Celcius.
This is what apps like Car Scanner are doing in the background when you want to display your coolant temperature.
Reactions: AmpOverload
I googled "ELM327DS.pdf" and found a new 68 page document that based on the first 20 pages I'm guessing will be the last missing piece of the puzzle. Really bothering me that I just accepted that all there would be was that simple command list I initially saw. The ineffectiveness of search engines when it comes to extremely esoteric subjects like this has rotted my brain fr.
Whatever... still glad I found this place and I'm sure I'll be back.
E: oh, I guess that popup that prevented me from hitting submit was an alert that others had posted since I refreshed the window. Don't know if it'll let me edit but my scanner is "kitbest". At the time I bought it, almost exactly a year ago actually, it was the highest rated/best seller on Amazon.
I took a look, found mixed reviews but that is to be expected online.
The lowest priced Veepeak is far more popular. This Veepeak model works fine when using it with just one android device. Gets troublesome when using with more than one Android device.
A somewhat more expensive Veepeak is a better choice when pairing with multiple Android devices.
I think I currently have like 4 or 5 of the cheapest Veepeak, 2 of the model shown above and 1 of the next higher level, the OBDCheck BLE+.
I may need an intervention :wink:
  • Haha
This is bordering on off topic perhaps, so forgive me since I'm still extremely new here, but... what's going on with the SDM in 1998 and some early 1999 model year GM vehicles? Most of the cars I've looked at (98 GMC Jimmy, 99 Oldsmobile Alero, 98 Saturn for explicit examples) have a "tan" wire (circuit #800) running from the SDM to slot 9 of the DLC and the most descriptive description I'm seeing on the diagrams is "UART Serial Data". My guess is there's an adapter that uses pin 9 instead of pin 2 for the bus+. Doesn't make sense to me to use an entirely different network protocol to program the SDM when J1850 VPW "class 2" had already been well defined by then. Then again, it doesn't make sense to isolate the SDM from everything else.
That brings me to another set of vague but perhaps more on topic questions. 1999 Saturns have a purple wire running from pin 4 of the SDM connector to pin 1 of the DLC, which the diagrams call circuit 1807, which anyone reading this is probably aware that 1807 is always (in 1996-2008) the main class 2 bus+ circuit. Starting in 2000, pin 4 of the SDM, which is identical to the 1999 one AFAIK (SIAB with new SDM first available in 2001), goes to the BCM instead of pin 1, and according to the diagrams, there's another purple wire going from slot 5 of the SDM to the IPC. I've never verified this, but it's got me scratching my head. If the SDM is connected to the BCM, which is obviously connected to the IPC, why the redundant wire?
I've completely disassembled the interior wiring in my 99 SL2 with the one exception being the SDM, since I couldn't figure out how to get the connector off without breaking it. Supposedly, there's an "airbag telltale lamp driver module" somewhere in the 99, which supposedly controls the airbag light in the otherwise fully-PCM-controlled cluster, so maybe it's under the main SDM case. I tried just looking at the wires but after 25 years, the tape around the bundle running under the center console, which was surprisingly well done, is completely petrified.
Anyway, backtracking a bit... is it safe to assume that any purple wire identified as circuit 1807 on a 1996-2008 (or whatever, before the switch to using the CAN bus for OBD-II) GM vehicle can be connected to the DLC pin 2 wire? I'm guessing that is so and that there was (is?) an adapter for the 1999 model years still lacking a BCM that effectively "shorts" pins 1 and 2 together, temporarily connecting the SDM to the main network and making it possible to check/clear unlatched B codes from the SDM.
By the way, the reason I originally got interested in this is the radio. The 1997 S-series coupe/sedans had a OEM/"Delphi" brand 12 disc trunk mounted CD changer option that works when the "AX" button on the head unit is pushed. Even though the radio isn't connected to anything else, I figure what the manual calls the "E/C Data Line" going between the head unit and the CD changer is really class 2 connection and if so, that would mean it would be rather trivial to trick the head unit into thinking the CD changer is available and I could listen to audio from my phone's AUX port. It would also mean I could assign functions to e.g. the RDM button. I am almost certain I remember a thread on the now defunct saturnfans.com forums where someone did exactly what I'm talking about, although it may be using a different protocol.
But we'll start with the DIC messages and work from there :smile: Thanks!
I've been doing a lot of research on the Class 2 messages in my 04 Suburban, including XM (DRR) and various radios. Here's an excerpt from the DRR section, specifically the exchange between radio and DRR when XM1 is selected on the radio:
Code:
(AA A5 89 1C B2 XX is required before radio will display XM band, e.g. AA A5 89 1C B2 03 for normal operation)
When XM band is selected, RADIO sends these functional messages:
6A A4 80 99 B2 2E                        Audio Tuner/Receiver    Load Command Ext (B2)    Q    19: 2E (XM Action: Band 1)
EB EA 80 3A B2                        Displays            Status Req Ext (B2)        3A (request XM band text)
6A 94 80 86 B2                        Audio Control        Load Command Ext (B2)    Q    06 (device on/off stage 2? on with Q)
If there is no response, the latter two are repeated several times and then "ERROR" is displayed on the radio and the following message is sent:
6A 94 80 06 B2                        Audio Control        Load Command Ext (B2)        06 (device on/off stage 2? off without Q)
If DRR is attached, however, it responds as follows:
6A A4 80 99 B2 2E:
    AA A5 89 99 B2 2E                    Audio Tuner/Receiver    Report Status Ext (B2)    Q    19: 2E (XM Action: Band 1)
    AA A5 89 18 B2 00 01 81                Audio Tuner/Receiver    Report Status Ext (B2)        18: 00 01 81 (Tuning: channel 1, band XM1, preset 1)
        RADIO responds with:
        6A A4 80 99 B2 00             Audio Tuner/Receiver    Load Command Ext (B2)    Q    19: 00 (XM Action: None)
            DRR responds with:
            AA A5 89 99 B2 00            Audio Tuner/Receiver    Report Status Ext (B2)    Q    19: 00 (XM Action: None)
6A 94 80 86 B2:
    AA 95 89 86 B2                    Audio Control        Report Status Ext (B2)    Q    06 (device on/off stage 2? on with Q)
    if no further data is sent by radio after after 4 seconds, DRR sends:
    AA 95 89 06 B2                    Audio Control        Report Status Ext (B2)        06 (device on/off stage 2? off without Q)
EB EA 80 3A B2:
    AA EB 89 BA B2 01 02 58 4D 03 04        Displays            Report Status Ext (B2)    Q    3A: 01 02 58 4D 03 04 (XM band text: "XM")
NAV RADIO also sends:
8A 94 80 89 B2                        Audio Control        Load Command Ext (B2)    Q    09 (device on/off stage 3? on with Q)
DRR responds with:
AA 95 89 89 B2                    Audio Control        Report Status Ext (B2)    Q    09 (device on/off stage 3? on with Q)
(if asked multiple times in rapid succession, sometimes it reports Q then not Q)
Once XM band 1 is selected, the following message from DRR sets text on radio:
AA A5 89 1C B2 04                        Audio Tuner/Receiver    Report Status Ext (B2)        1C: 04 (XM Status: TUNING)
AA EB 89 B6 B2 01 02 41 42 03 04            Displays            Report Status Ext (B2)    Q    36: 01 02 41 42 03 44 (text: 'AB')
AA A5 89 1C B2 03                        Audio Tuner/Receiver    Report Status Ext (B2)        1C: 03 (XM Status: idle)
    (NOTE: 1C: B2/03 is required to close out 1C: B2/04, otherwise radio displays text, but user is stuck and cannot change bands, etc.)
multi-line text requires toggling Q for each successive message
    AA EB 89 B6 B2 01 02 41 42 43 44
    AA EB 89 36 B2 45 46 47 48 49 4A
    AA EB 89 B6 B2 4B 4C 4D 4E 03 04
note: radio accepts message so long as data starts with 01 and ends with 04 -- 02 and 03 do not seem to be required
    AA EB 89 B6 B2 01 4D 45 4F 57 04 (displays MEOW)
Attached is an excerpt from the JSON file I created for my decoder with some of the relevant functional messages.
Just wanted to follow up on my last veering off topic comment. I recently learned that GM circuit 835 - referred to as "E/C data line" in the Saturn pinouts - is indeed something other than class 2. Its full name is actually "Entertainment and Comfort Serial Data Bus" and this appears to be the only information publicly available at present. If you don't wanna look, the E&C bus uses 34 bit messages running at 1000 bit/s and uses near battery voltage to represent idle and near ground to represent active.
Unfortunately, there are multiple references visitable from that link that erroneously describe class 2 as being 7V active and 0V passive, full stop. According to my copy of J1850, the VPW variant, which we all know is what class 2 is based on, uses two different symbols each for '1' and '0' and has 7V active and 0V passive pulses. Specifically, '0' is either 64μs passive followed by a rise or 128μs active followed by a fall, while '1' is either a 64μs active followed by a fall or a 128μs passive followed by a rise. This particular design ensures that when multiple nodes start transmitting simultaneously, the node(s) trying to send a '0' bit will always "win" over nodes trying to send a '1'. It's why the priority bits are at the beginning, why lower priority values take precedence (1 beats 3), and why addresses were assigned to the particular integer value they were.
The other thing is circuit 800, called either "serial data" or "UART serial data". I believe this was GM's predecessor to class 2. According to one of the references in that link it's a 8192 baud protocol that requires a master node - usually the BCM - to give permission to other nodes to send.
Never did figure out why the 99 Saturn's SDM is isolated from the other class 2 modules except when a scan tool and special adapter is attached. Was there some pervasive fear in the early days that modules would fail in a way that takes the entire network down with them? It would also explain why that E&C bus was still being used as late as 2005, even though class 2 should have been more than capable of handling everything it did.
This morning, I realized I can figure out what modules a vehicle possibly has by looking at the list of defined error codes from the range U1ddd to U1255 inclusive, where ddd is the zero padded decimal representing a dead module's physical address. E.g. U1088 is set when a module previously stored the SDM (physical address 88, i.e. 0x58) in its list of installed modules, but the SDM fails to successfully transmit its SOH message for 5 seconds. The 2005 manuals are especially handy as it flat out includes the list of modules in the form of a table containing both the full and abbreviated name.
I looked at the manuals for probably three dozen vehicles between 1999 and 2009, mostly 2005, and one curious thing is there was no "lighting" based modules even though there are 16 addresses reserved for that (0x70-0x7f). Gonna include a screenshot from my spreadsheet but I suggest if anyone stumbles upon this and wants to know how to get a list of module physical addresses, just look for the aforementioned list of errors. Apologies if someone else has already mentioned this and I didn't notice it when I skimmed over the entire post.
If one wants to know what modules are currently active in their given vehicle (Older vehicles using SAE J1850 VPW of course) you can query the vehicle like the following where I used the terminal mode of the TorqueScan add-on for Torque Pro.
Anyone have snapshots of class 2 traffic during ABS activation? Preferably on the older three channel "ABS VI" from 1996-1999 (which uses two solenoids, three motors, and four sensors) or the generation after that when DRP and standardized C0### codes was added. I have a theory that, at least in the older systems, pure ABS activation is determined entirely by wheel speed sensor data. I.e., the EBCM determines vehicle speed by using the wheel speed sensors and only activates whenever it calculates the wheels are decelerating faster than the vehicle possibly could.
I'd think the FSM would say exactly what causes ABS activation but from what I can tell, they all say something like "go 45 on an empty straight road and brake as hard as possible" to confirm a repair.
On my 06 Avalanche, I previously had an issue where the ABS was kicking in nearly every time I stepped on the accelerator from a stop, and it was solved by cleaning/replacing the front wheel speed sensors. I don't have a snapshot of that occurring, but figured the situational info might help your research.
Anyone know the secondary IDs for the DRL, front fog lamp, bulb out, and rear hatch ajar telltales? Actually, I wouldn't mind a list with all of the telltales that are missing from J2178-4_1999. Also, I still haven't figured out what "super lock warning system" (sec id 0x22) is supposed to be...
By the way, there is a "vehicle speed control" entry for 0x24, but I'm only about 90% sure that's referring to the "cruise control on and ok" indicator and not a warning for when the limit of a governor equipped vehicle is about to be reached.
Try this one for hatch ajar:
Liftgate Hatch AjarLFGT_Hatch_Ajar224101Lookup(Bit(A:1)::0='Not_Ajar':1='Ajar')
Could not find anything on the DRL, front fog lamp, bulb out PID's
Making a list of generic parameters and the first roadblock is something I thought I remembered reading either in this thread or another on this forum: the cruise control disengage reason as text displayed by tech2, since I don't think it's one of the standard PRNs from J2178-2. It might vary between GM make/model but I'm betting only in that each one supports a subset and that e.g. 0x06 always means the same thing.
The following is a list compiled from the FSMs for 99 S series and 02 TrailBlazer.
* ignition 1 voltage signal outside "normal" range (varies but usually ~11..16V)
* stop lamp switch on
* stop lamp switch circuit failure
* cruise switch off
* cruise switch circuit failure
* clutch switch on (MT only)
* range switch reading indicates shifter moved to incompatible setting (P, R, N, or 1)
* range switch circuit failure
* internal PCM failure
* downshift to 1st (not sure if this would actually turn it off)
* speedometer outside range 25..100 mph
* rapid velocity change (decel>4mph/s or accel>10mph/s)
* throttle control circuit failure
* throttle position sensor circuit failure
* TC active (for TB only after 2 secs)
* ABS activation (TB only since 99 Saturn doesn't use ABS during TC.
* engine rpm outside valid range
Also, the Saturn FSM explicitly mentions cruise won't engage if the PCM hasn't seen at least one brake switch activation in the current ignition cycle... so I wonder what would happen if one were to start the vehicle with N selected, switch to D without hitting the brakes, get up to 30, then try to activate cruise. My guess is "brake lamp switch circuit failure" cruise wouldn't activate and it might even set a code.
The attached Excel file contains a summary of known PID's & DTC's. The PID data includes the ID & equation info necessary to use with apps like Torque Pro.
Reactions: SteelyGM
Thank you, something like that is exactly what I've been looking for! As to what I was specifically asking about, I see it has 4 cruise cancel reasons documented {0:'Brake', 4:'Coast+Disengage', 13:'OFF', 26:'DTC Set'}, which I'm assuming is decimal values and what the creator assumed it meant?
Anyway, wouldn't it be possible to nondestructively splice in a tech2 and Bluetooth elm327 adapter into the DLC at the same time? IIRC, there shouldn't be a problem configuring the elm to communicate on the bus using a different address than F1 or whatever the tech2 defaults to, assuming it's not possible to have the tech2 change its own address. If I'm right, it would be very easy to have the elm log the traffic while simultaneously commanding the tech2 to show parameters only accessible through mode 0x23 (diagnostic data by address) or to run tests, presumably using modes 0x31-0x33.
Hit send early, oops. Just wanted to add that I'm especially interested in getting ahold of the Saturn tests. E.g. there's one to command the cruise control module to try to open the throttle up 50%, one to test the trans solenoids, one that *has* to be done to relax ABS motor pack, and lately, I'd love to have the ability to command the EGR valve stay shut so I have maximum power when e.g. some ahole decides to try and kill me because I dared to pass them.
You are welcome! Not sure what you asking re: "decimal values and what the creator assumed it meant?"
As for non-destructively splicing in a tech2 and Bluetooth elm327 adapter; no problem, search "obd2 splitter".
In order to log OBD2 traffic while the Tech 2 is attached you will need to use a serial terminal emulator (such as "Serial Bluetooth Terminal" by Kai Morich, Android only) or the built-in "TorqueScan" serial terminal in the Torque app. This will allow you to *passively* monitor the data flows since you cannot change the F1 address being used by the Tech 2. Note, you will need to use a spreadsheet to decode the resulting HEX output in the logfile.
The resident ELM327 expert is @TJBaker57. He would be able to provide more details if/how direct control can be executed via an ELM327 connection.
Before I forget... does the "number of passed EGR flow tests" parameter ("2211bd" on the spreadsheet I think is what I'm referring to) rollover to 0 when it hits 255 or does it saturate, i.e. stay at 255 until a failure occurs?
Oh there was a reply... So I'm kinda familiar with coding and one thing that kinda drives me nuts in situations like this where people who aren't don't realize that the string "11" can mean binary 3, octal 9, hexdecimal 17, and of course decimal 11. The cruise control disengage reasons on the spreadsheet are all limited to symbols within the octal range so the only thing I can be sure it isn't is binary. I've only skimmed over that spreadsheet so for all I know it's mentioned somewhere I didn't see... I just make it a habit of writing numbers in a way their base is totally unambiguous, using the same syntax as the C preprocessor:
binary = 0b111
octal = 00111
hexdecimal = 0x111
everything else is decimal
Yeah, basically everything here and is in hex... since that's what the elm expects (and wastes time encoding/decoding), but it's that one exception that'll getcha.
Assuming I borrowed a tech2 instead of buying one and tried this little reverse engineering scheme, I would definitely be using C/Python to decode the traffic, mostly because even though I've made some complicated spreadsheets in my day, I just think it'd be faster to use regex to search for interesting tidbits.
Neverever
