DFWWIZ Cree/Philips LED headlights
Instrumental said:
Got an install question.
I have the stock HID, I'm guessing I pull power before the ballast and just replace the bulb in the housing. Is it that simple?
Sure is.
Midnyteryder02 said:
So even though u have to adjust the lights, how did you like them? Be sure to keep us posted :thumbup:
I like them. I'm going to take a pic tonight on my way home from my other job and post it...the street lights are few and far between. Once I get them adjusted, I'll take the same shot for a comparison.
I like what the LED lights do for light output and reduced current draw, but I am now hearing reliable reports that they run too cold to defrost or deice headlight lenses for those who live in snow and ice country. They may be fine for those who experience most of their winter driving at or near temps of 32F, but for those who often face below zero temps plus snow or road spray that freezes onto everything, they are not the way to go in the winter time! :no:
My son works at V3 Jeeps in Louisville and they have recently gotten onto the LED bandwagon and he was trying to convince me to run LED in my headlights. Yesterday after a snow event he called and said to hold off -- he said that virtually every customer who installed the LED in their headlight or foglight system were compaining that they simply would not defrost the lamp housing.
I still like the lights and what they do, but I drive for 1/3 of my year in harsh winter conditions where the ability to keep the headlight lenses frost free is the difference between life or death on rural roads with deer, snow drifts, etc.
Just wanted to pass this information along to others who are considering making the jump.
Hmm maybe a spring/summer bulb then? Its not that hard to change out bulbs.. but then again do I want to keep switching bulbs every fall n spring?
good info there since its below 32 here for months it seems. mabye ill try a set for the fogs first.
This should also be solved by my plan to run HID low and LED high, w/ Quad beams. THE HID should keep the lenses clear. They'll certainly keep the low beam portion clear and if your in driving snow that sticks to the lenses and have your high beams on... well then you deserve issues since you shouldn't have the highs on in the snow anyways.
I plan to do the same on my Malibu, and no way in hell I'm changing bulbs often in that thing. Gotta remove the entire front bumper to change bulbs.
The thing is when I had HIDs in my headlights and fogs they were hot to touch but never melted any snow. It was always covered and iced over
I've got the headlamp washers, I imagine that should take care of snow and whatnot. We also garage park in the winter, I can't ever go back to scraping ice in the morning, I'm addicted to a snow and ice free car.
No pics from last night, too much blowing snow and there was another vehicle behind me. Plus, the drivers side has an intermittant flickering on and off, I have to get a hold of Kevin.
Low beams? I know Kevin said there's a problem with drl. But since it was at night it might be an old driver.
Yep, low beams. I have a DRL killer, so it's only when the lights are on. I was thinking it was probably the driver having issues.
I've put my old HIR bulbs in there for the time being. I sent Kev and email but haven't heard back from him yet...although I know he's pretty busy with these things selling like hotcakes.
Matt,
what drivers did Kevin ship with yours? the little black box 1.5" x 2"?
Or the bigger 2" x 3" with mounting ears?
If the smaller set, they are known to fail. Contact Kevin and he will get you squared away.
neohio said:
Matt,
It was the little black box with one small mounting tab. I'll send him another email.
Thanks neo!
Thanks neo!
Def the old one. He might be busy due to the sending out if lights as you said, and china/Asia is going through New Years "harvest" soon. Hopefully he has backup drivers for you
Just have to test this morning to see if the problem follows the driver and get back to Kev.
i want to do the lows and the fogs so bad but i cant convince my wife that we need $160 for lights. dammit guys help me convince her
Few thoughts...
Drive at night? See better.
Have kid(s)? See better.
She drive it? She can see better.
Longevity? Investment
Vandalism. :lipsrsealed:
(Something's telling me you just have to do it and see if she notices. Easier that way. Will she make you take them out? :raspberry: )
Playsinsnow said:
Few thoughts...
Easier to ask for forgiveness than permission. :yes:
What is there to convince? When I have to replace the low beams it is going to be around $50 - $60 to replace the halogens. To switch to LED is $70 + shipping. Tell her that you have a flaky low beam and this is brighter and safer then running the ones that are in the parts store.
you guys are no help.ha ha. i know its easier to ask for forgiveness but i have to sleep with her not you guys. i like snuggling and if shes pissed the dog gets my spot and im pulling couch duty. im gonna have to email DFW.
Reactions: BHAMER
Ok so Matt swapped drivers to see if problem follows and now he says both are working again. Connections are pretty critical so if they don't click together and you are dealing with 24 volts coming off the drivers and I know the factory is still assembling neg and pos backwards sometimes.
DRLs need to have a relay/harness is what I'm being told now or you can do the capacitor mod which makes full 12 volts to the headlights all the time. I went to Fry's electronics yesterday and bought all their 10 uF 35 volt caps to make some of these little mods up for sale for a few bucks... they install under the rear seat in the BCM from the pink/white stripe wire to a ground.
Also went and picked up the stainless laser cut lighted SS door sills yesterday and will get at those-weather cooperating. The Aero Sills are being sorted out from the drawing and will be cut shortly and I have a buddy looking at several CNC machine shops for me in the making of the billet aluminum door sills and bumper plates.
Yup, :yes: I'm a busy guy. :crazy::eek::wootwoot:
Mine are backwards. The clip can't clip because they are reversed, but they are on tight. I am still getting a little flicker on the passengers side, but will look at it after work this morning and keep you appraised.
Lol mine were backwards too! Nothing a little electrical tape couldn't fix! Lmaooo
If you pry inward on the "leg" on the inside of each prong inside the plug with a sharp pick, you can pull both prongs out and reinsert them to the correct sides.
I'll do that when the other stuff arrives. Thanks mate! :thumbsup:
Yep, I did this (carefully) on my old Camaro as it was wired backwards too.
GM and their wiring sometimes :crazy: Just glad VW wasn't involved with it or we'd be really screwed :rotfl:
Reminds me of why brides wear white... "So the dishwasher matches the stove and fridge..." (Ba-da-bump... :biggrin: )
My wife has learned to listen to me over the years because she too likes to see in the dark while driving. I don't have to "buy her off" to get her permission. Yes, she gripes about the cost of car parts -- until she hears the stories of people at work where they are spending thousands for stuff I'm doing in the driveway for the cost of parts -- and for the record, so do I. I don't like what parts cost any more than my wife, but it takes parts to keep stuff going, including good lights.
c'mon.
Amazon.com: Philips 9006 Standard Halogen Headlight Bulb (Low-Beam), Pack of 1: Automotive
not sure why you want more expensive lights unless you drive off road or way out in the boonies. where I drive, the real need is to be seen and to see the road. (and not blind the other guys so they squint and cut in front of you)
I don't have any issue with anyone who wants to put nicer lights on the rig, but the default looks to me to be under $15 a pair. ( and my experience is they do not really go as pairs so you could spend half that.)
The whole point IS to see the road better :tongue:
Well, mostly. Some people do it "just because" which is fine too lol.
The default is enough to pass DOT standards, and are certainly better than some other cars' headlights out there that I've seen, but nothing stellar either. Always room for improvement :biggrin:
meerschm said:
c'mon.
Trust me...where he drives he needs all the lighting help he can get!
Years ahead of a mid-2000s Grand Am. The lights don't do diddly in the dark, even fog lights hardly helped, however with those you could see what pothole you were about 12" from at highway speed if your eyes are quick enough.
Can't really use those on the highway too well :tongue:
I've been tempted to wire in a switch to manually turn on my reverse lights, so if someone is being stupid behind me I just lightly push the brake pedal enough to turn the brake lights on for a sec, then flip the switch so the reverse lights kick on. I wonder what people's reactions would be :crackup:
meerschm said:
c'mon.
Have you tried traveling off-road with the standard halogen bulb? And they should be replaced in pairs to keep the lights fairly balanced... Besides with my luck 2 days after changing the one I would be at it for the other side.
meerschm said:
if you need the light in the boonies, why not something like this?
Amazon.com: 20" LED -22" OFF ROAD LED LIGHT BAR FLOOD/SPOT COMBO BEAM- 3W LED-120W-7500 LUMEN: Automotive
( I actually have considered such a solution mounted backwards for those folks who come up behind my jetta with mis-aimed lights on the highway.... not that I would really do that.... but have considered it. I usually settle for calling them a J*** **S, much to my wife's amusement.)
I am actually looking at the 30" version and then lighting for the rear and sides.
I have seen videos on YouTube with guys who upgraded their reverse lights with HID kits (Made for reverse lights, not headlights) and wired them with a switch and can turn them on while driving down the road to freak out tailgaters.
[video=youtube;N4B5o_YtDwk]http://www.youtube.com/watch?v=N4B5o_YtDwk[/video]
Have to say sorry for diverting this thread.
When I was a young airman in the USAF, one of the NCOs told a story of wiring up a landing light from an F-4 in the back seat of his MGB-GT in Hawaii.
the story was as you might expect: dark road, impatient bright-flasher. the lamp turned on for a few seconds, which lit up the countryside like daylight, and when he turned it off, he could see headlights bobbing up and down in the pineapple field.
we all had a good chuckle, and went back to work.
That's why I have this for tailgaters...
[/URL][/IMG]
huntylterer
