Hi there.
I got a 2005 gmc envoy 4.2L from a coworker. It was in limp mode when I got it, but started all the time.
I had to splice a few wires on the wiring harness, and MAP sensor to get it out of limp mode.
Once I did that, it ran great for one or two times, where I had no issues. Then, I got a p0302 code for cylinder 2.
I got it to my driveway and it didn't want to start anymore.
I got a new coil for #2 and swapped out all spark plugs with iridium 41-103 ac delco from oreillys.
It would just crank and crank, but no start at all.
Then when I was about to give up, it cranked and started. I drove it on saturday for about 45 minutes. No CEL, no rough idle or anything. Beautifully.
I got it back to my house, turned it off and came back out about 20 minutes later and it doesn't want to start again. When I checked the scanner, there was a code for p0014.
I did an oil change, because the car was sitting for awhile. Now the code doesn't come up. It doesn't start.
I'm clueless as to where to begin to diagnose it.
If anyone can lend some advice as to where to check next, I'd greatly appreciate it.
Also, some questions...
Can I eliminate the starter as being an issue if it cranks?
Could the battery be an issue if it is old?
Can a fuel pressure test or anything along those lines be done if the start won't actually start?
Do the envoys have any issues with grounding or whatnot that could be an issue?
