ADDED: thinking about your meter testing some more. How about this impedance test. Disconnect the connector from the back KS. Locate the low reference pin. This low reference is coming from within the PCM. I believe you measured the impedance on the pin to a "known good ground" and got an "open". That's good as that means there is no short to ground. However, it doesn't really tell you if the "low reference" is indeed "low" meaning it isn't some form of "non-zero impedance". So then how about testing from one low ref to another with the chance that perhaps in the PCM, various low ref's come from a common source. As a guess, I would try using the MAP sensor. It too has a low ref. Disconnect the connector therein, and do a resistance measurement from the pin in the map connector to the low ref in the KS connector. Do a second test with the same setup to the other KS (the good one)... which you then compare. Of course, IF the low ref isn't coming from a common circuit in the PCM, it won't help but it doesn't hurt to try. The alternative is "guessing" at finding a low ref at the pcm some where that is common.... but I hate playing with the PCM connectors and pins because you maybe opening up a "can of bad connections" thereafter.
ok, so I tried to test this, but not sure exactly what the "bias" test is doing so I'm not sure I'm doing this right. Then new info at the bottom of this post.
Turned key on but engine off KOEO
Unplugged MAP sensor, it has 3 wires.
Gray - 5v wire - tested this by putting meter on DC volts, grounding black probe to battery terminal and probing with red probe on the connector pin, meter reads 5.03 volts.
Green - Signal wire - didn't touch this wire pin.
Orange stripe - tested in DC volts, red probe on positive battery terminal and black probe on orange wire pin, reads 12.25v
I then tested the voltage across from the orange stripe wire pin to the gray wire and also got 5 volts.
So then doing the same on the knock sensor connectors, I put the KOEO, put meter in volts DC, red probe on one pin in the connector and black probe to battery ground terminal, I get 4.05 volts, BUT then, I move the red probe to the second pin on the connector trying to make sure I have the reference pin and the power pin identified, and I'm still getting 4.05 volts! I did this with both knock sensor connectors and its the same for all 4 pins of the two connectors. 4.05 volts. The ole AI chatbot tells me maybe this is why its throwing a low signal b/c it should be sending 2.5v up one wire and back to the computer thru the reference wire but since its 4.05v on both legs, its reading it as 0.00 volts and throwing the low signal code.
The AI then has me unplug the PCM connector and test again to make sure the voltage isn't coming from some other source with a melted wire or cross voltage up these wires.
So I turned off the key, disconnect batter, unplugged the middle PCM connector that corresponds to the knock sensor, connect battery back and then tested this again, and now I get zero voltage on the pins of the knock sensors.
So I'm not sure about the reference test on one of the pins if they are both reading 4.05v.
I didn't notice both pins giving me 4.05v before, I thought it was only one of the pins on each knock sensor connector.
