I agree... I wouldn't attempt any bearing replacement as even in past vehicles, the bearing "effort" was substantial. Spinning the alternator doesn't appear to indicate any mechanical issue.
I continue to monitor the voltages continuously (via a lighter plug-in display). Reading up more on the charge system "semantics", it would appear the regulated voltage control system (RVC) "thinks" it needs to be in some form of "battery sulfation mode" as the voltage is relatively high 14.7-15.0 for a period of time then proceeds to drop thereafter to somewhat normal levels (13.8-14.1).
The battery is new (manufactured in sept).
I haven't removed the alternator for inspection yet as its darn cold... not sure when that might be achieved.
New question though.... Have people seen failure / replaced the SARVC block at the negative pole / cable? It appears to provide some of the 5V modulation signal towards the charge system / pcm which ultimately feeds this back towards the alternator.... if my read / understanding is correct.
The cable appears to be a cheaper focus point of repair than the alternator which seems to be responding in general as I don't see things like dimming lights..... although the effort in changing out the cable might be more severe in the current climate...
Further to the RVC operation, my vehicle sees multiple state of charge (SOC) events (key off for more than 24hours) which again, if I read the RVC operation, if the module has issue, then perhaps its readings of SOC suck...
and the charge system / control ain't so good.
Although the cables / contact look good maybe some further cleaning is needed.... certainly can't hurt...
