2007 trailblazer won't start after trying a few things
Shelby2010
4
Oklahoma
Have an 07 trailblazer. The battery was draining every day. Put a new battery in, changed the alternator. Still draining. Used mutli meter and checked every fuse in the hood and back. Found that the ignition switch was drawing voltage. So we changed the ignition switch and now the car will not start, it won't even crank over. Any help on this? Note that the car started and ran before this just the battery was being drained!
Recheck that the tooth engagement of the switch is correct.
Reactions: djthumper
Shelby2010
4
Oklahoma
I have moved the tooth part several times to try and get it in the correct spot I may still have not got it correct. I've looked online and YouTube for instructions. Is there a set spot you know is correct?
Shelby2010
4
Oklahoma
The dash lights up like normal just won't crank. No security light or anything. The check engine light stays on but it was on before so I don't know if it means anything.
Shelby2010
4
Oklahoma
So we found that while I was installing the ignition switch I must have pulled a wire loose from a connector under the steering wheel and we wired it back together and the car cranks now, pretty sure it needs a new battery now. However something weird the rear windshield wiper comes on while the switch is off now, don't know why. But thanks for the help!
oldfoggie
8
Canada
measure the battery voltage, should be about 12.8 volts if full charge, keep monitoring the battery voltage while you start the vehicle, if battery voltage drops below 10 volts replace it
10,685
Please keep in mind, this is an almost 4 year old thread. The OP hasn't been back to the site since...
Mynamesjeff
