So you drive through this...how long does it take to exchange your rear end fluid after it fills with water (which came in through the vent), realize after leaving this water hole you attempt to stop and your brakes arn't for you forgot to drive while holding your brake pedal down and you crash into that tree that just jumped out in front of you, and that pot hole which formed since the rain came just bent your rim and caused the tire to split open. So maybe you drive through this mess, but you now need to rebuild your rear-end cause your gears and bearings are shot, you lost a tire and rim, and insurance rates go up due to that tree which jumped out in front of you. Sounds like fun to me. On second thought I would pass or maybe wait around a while filming others trying to go through this and uploading it to youtube for everyone to laugh at. Or go talk to an old buddy and use his Amphicar to drive through this.
redbeard
You may not like guns.
That is your right.
You may not believe in God.
That is your choice.
But if someone breaks into your
home, the first two things
are going to do are…
1. Call someone with a gun
2. Pray they get there is time
