What is this plug
Buloushie
3
Charleston wv
Bought a 02Trailblazer ltz had a few things stolen of of itgas filler neck,one wheel and tire,battery and catalytic converter
But i have a plug unhooked that i can’t find what it plugs into CA5C37DB-DCA5-4E56-9B9F-C57DBAC25534.jpeg
10,687
Looks like maybe the plug for the intake air temp sensor?
Yeah, there's a sensor on the intake tube that I'm pretty sure that it goes to. You're missing the intake tube, resonator, associated PCV hose, etc.
Buloushie
3
Charleston wv
Which is where? I have looked everywhere for where this plugs in at
No i just moved them out of the way to take the pic. But i see no where it would plug into on the tube
10,687
On the back of the intake tube, where it connects to the throttle body, is where your sensor should be.IMG_20180122_224054.jpg
Buloushie
3
Charleston wv
No that’s that plug is there and plugged up
See the wire that is above the one I’m asking about that’s goes out of the pic? That is the plug you are talking about
Take a look at this, and see if it matches up. The title of the video is in the screencap (but it's a lousy 'how-to')
Mounce
13,667
Tuscaloosa, AL
SAIS solenoid plug? I see the block off plate is there and solenoid is missing but maybe it had the solenoid until failure and then a previous owner removed the system? That's my guess, exactly where it lines up to. But I'm not familiar with the SAIS as I don't have it.
Either way, appears to be an 8 (or so) pin plug.
Yeah the more I look at it the more I realize it is too big for that air temp sensor.
It has been too long since I had my 02 TB so I can't remember all of it.
cace68
6
Colombia
[QUOTE = "Blckshdw, post: 551598, miembro: 6045"] Parece que tal vez el enchufe para el sensor de temperatura del aire de admisión? [/ QUOTE]
That"s rigth that conector is for IAT sensor.
7,782
This image displays what @Reprise suggested... it is an interior closeup of the Shrouded (7) Male Pin Connector for the FUEL RAIL EFI Wiring Harness. The plug that is free on your engine looks like the Female Counterpart leading to the PCM for this Connector:
This thread is from January. I'm sure he figured it out by now.
Joe102938
