edibleMango
Hey all. I am new to this forum but I have found other posts on here to be useful so I figured this would be a good place to ask my question.
Last year I bought a 07 TB with the 4.2. It has about 230,000 on it but its in beautiful shape. I just rebuilt the front diff on it about 2k miles ago and everything has been running amazingly until this morning. The truck had been parked for about a month due to my traveling for work. I went out to start it and it started right up without issue. I walked away to let it warm up but when I came back (about 5 mins later) I could hear some irregular knocking not rhythmic at all. It honestly sounded like a bad AC compressor to me AND it only knocked when the AC clutch was engaged so I passed it off and shut the ac off. The sound disappeared initially. Only when I put it in gear and the revs dropped slightly it came back.
Facts:
What I have tried:
Trying to figure out where to go from here. I was thinking to replace the cam-phaser next but I am wondering if anyone has had anything similar to this. I found a post by Mooseman from several years ago mentioning that their knocking went away with a bit of oil pressure due to a bad hydraulic chain tensioner. This seems to also make sense because a bit more rpm causes the knock to go away.
Video of it knocking:
Video of the internals after removing valve cover:
Hoping to find a resolution here soon as my wife wants her TB back!
Facts:
- The knock is very loud at the front corner of the valve cover just above the VVT cam-phaser.
- Revving the engine slightly (about 1000 RPM) makes the knock disappear and it does not seem to come back even up to around 4000 RPM. However once the RPM drops back down for a second it will come back.
- Changed the oil about 1000 miles ago. Used a different brand of oil than normal. 5w30 full synthetic ultra platinum Penzoil.
- No codes - although it has not run for very long since it started knocking.
What I have tried:
- I started by removing the serpentine belt and running it for a sec. I put it in gear with the parking brake engaged and could hear the knocking. This rules out the PS pump, Water pump, Alternator, AC compressor, Tensioner, and fan clutch.
- I then replaced the VVT Solenoid just in case it was stuck open and causing oil starvation to the chain tensioner. No dice. It is worth mentioning though that the old solenoid was clean as a whistle.
- I decided to remove the valve cover and take a look. Expecting to see something obvious. I was disappointed - It is the cleanest 230k engine I have ever laid eyes on lol.
