Hi, so I recently bought a 2006 Trailblazer 5.3 4wd with 176000 miles on it. I get it to my house and it is throwing a P0301 code (cylinder 1 misfire). Okay, no problem. Changed the spark plug, no result. Swapped the spark plug wires, no result. Swapped the coil pack. No result. Changed the fuel injector, no result. I'm so confused on what I could be! It does have the AFM (DOD) system so I swapped the valve cover to the upgraded design but that didnt do anything either. Now, I'm looking at the real time data and I have misfires on 1, 2, 3, 4, 5, 7, and 8. Although 1 and 8 are by far the worst, 2 is concerning, and 3, 4, 5, and 7 are running one misfire for every thousand misfires on 1. I am pretty sure compression is good but I have no idea if the torque app can actually give an accurate reading for that nor what it should be. Has anyone run into this? I mean this is getting ridiculous and is starting to make me feel like I really got screwed by buying this truck. Everything but the engine is in great condition though. This is really urgent as I need the truck to be in good running order ASAP!
