NEED HELP u1301 u1000 u1064 u1152 p1481
yazan
183
iam getting this codes randomly , not all the time and its shown under the power train section . not the body control
some times the p1481 set with the other codes , sometimes not
and the fan clutch also some times engaging at full speed while not needed , its low temp ,
any help please
4,024
The P1481 means there's possibly a short in the wiring for the fan clutch. Check for frayed wires between the clutch and the plug.
The rest are communication problems in that one or more modules are not communicating to the system. The U1064 may indicate a problem with the ignition switch being a problem, which is a fairly common issue.
7,773
Agree with Matt ...
These are Trouble Codes for a Break Down in Communications on the Single Wire, Class 2 Network of a 2008 Chevrolet Trailblazer 4.2L vehicle... and THIS Mechanic covers his EXCELLENT Diagnostic and Repair approach in the following 30 minute Video that may prove very useful in this case.
Having the Proper Electronic Diagnostic Tools (GM Tech 2, Autel Tool, DMM and Lighted Pin Probe) allows this Man to carefully run ALL of these Odd UXXXX Codes to ground. I'm also Suggesting to everyone that Downloading and Keeping THIS Video in your "Mechanic's Video Library" will eventually pay off during such similar Module Failure Troubleshooting Issues:
freddyboy61
This is a great demonstration of the complexity of the modern vehicle electronic systems. If a mechanic does not have training in this area, troubleshooting will be hit and miss, and expensive for the customer.
Reactions: yazan and mrrsm
Gdub2306
