transmission no gears when warmed up
jdutcher4426
6
37148
I have a 2006 envoy my wife was driving down the road and it felt like it went into neutral. If let sit for a few minutes it will go into any gear, for a few minutes then its like its in neutral again.
Fluid level and condition good? When was it changed last?
What kind of mileage does the truck/tranny have? Something like this sounds more like a tranny shop should be consulted.
16vcabman
113
Ortonville, Mi
I agree with Mooseman. Seals in the hydraulic system can fail when hot. It could be electrical too. Find a reputable company that others have trusted
jdutcher4426
6
37148
here are the codes that were pulled U1026,C0244,C0161,C0196.C0455,C0110,P0300,P0171,P0306 could any of these caused the issue?
jdutcher4426
6
37148
200,000 MILES here are the codes that were pulled U1026,C0244,C0161,C0196.C0455,C0110,P0300,P0171,P0306 could any of these caused the issue?
jdutcher4426
6
37148
Update: I changed the fluid, the filter both shift solenoids and cleaned the valve position pressure switch. and it is back up and running
tak13
14
NH
The first code has to do with PCM communication the "C" codes is a mix of steering and abs problems, and the "P" codes are for misfires and 171 is a lean code. You got all those codes at one time?
keithdm
