so after my 2 posts, one about replacing\cutting my resonator, and the other about flushing trans fluid...I took my car to the muffler shop to get a new resonator, they said they couldnt work on it because of a bad gas leak. i looked underneath and didnt find any gas leaks, coming from the tank all the way up through the lines. BUT i did find the red fluid leaking from the transmission line, (maybe they thought it was gas). Anyways the leak must of started after i installed a new water pump and moved the trans lines to remove the fan clutch. Here are some pics where the leak is. I wanted to take a utility knife and cut away the wrap around the lines but i thought i would jump on here and ask you first. Now ive read about the skinny arms being able to do this, and i do have in fact skinny arms, i couldnt mess around up there though cause the cat was still hot from the drive home.
