Transmission issues please help
chris6822
17
moses lake washington 98837
So I bought an 04 Buick Rainier I thought it had just a problem with the servos and the transmission but that turned out not to be yet so I replace the transmission with a used one it works fine before I installed it after putting it in I drained all of the transmission fluid change the filter and replaced the fluid and now I'm not getting anything it won't move in any of the years
chris6822
17
Sorry it won't move in any of the gears
Is the pump working? Take the cooler line out of the driver side on the radiator and slip on a hose. Put the other end in a large container. Start the engine. Tranny fluid should start pumping out. If not, the pump was likely damaged during installation.
8,056
When you replaced the transmission, did you also replace the torque converter?
chris6822
17
Okay pulled off the hose and started it up and got nothing and then I started it up again and tried putting it in gear and still got nothing
Sorry, didn't see this thread before I added to the other.
Does it have fluid? If the converter was low, it could likely pull enough fluid to starve the pump.
Check the fluid level with the engine idling.
8,056
The torque converter could be the problem as well. On my 4T60E, the internal vanes had imploded.
What I'm thinking is the TC wasn't properly engaged with the pump and destroyed the tangs on the pump. Not the first time. This is what happens when the TC isn't in properly:
img_20160823_040021-jpg.80772
Good point on using the TC from the 4.2. Even if it bolts up to the 4.2 flexplate, the stall speed with the 5.3 TC would be totally different.
chris6822
17
Yes it has fluid I pulled off one of the transmission lines from the radiator and nothing came out when I started it
What it has the same torque converter that was in the original transmission the other transmission worked it just didn't have 3rd or 4th gear
chris6822
17
What do you mean the TC the transmission cooler or the torque converter
I don't think the TC itself is the problem, looks like the pump got damaged like in the pic.
It can but you basically have to take the whole tranny apart to replace the output tail shaft.
JayArr
504
Mission BC Canada
couple of quarts?
To fill the transmission put a few quarts in through the dipstick and start the engine for about 10-15 SECONDS. stop the engine and check the dipstick, it'll be empty. Repeat this process 2-3 times until you run the engine for 10-15 sec and there is still fluid in the pan. Run a little longer and check and you're full. About 12 quarts in total if everything was empty when you started.
Reactions: chris6822
chriswilson5585
