Ok guy I really need some help or guidance here. Two weeks ago on a road trip i got out my '05 4.2l Envoy and heard a weird noise coming from under the truck. Initially I thought it was a exhaust header leak as it had a ticking noise to something similar and well the transmission was shifting fine with no issues. When i got home I realize the noise was coming from the bell housing area. The noise was consistent whether idling or in gear. Thinking back when driving to work in the morning I would hear like a groaning noise in thre transmission tunnel area, but figured it was the A/C blower as transmission showed no signs of issue. So i figured it was either the starter or the flexplate causing such noise. I got the starter checked out and rebuilt and the noise was still there. So I had an extra flex plate and took it to the mechanic to have it changed as I figured it had a crack in it and that was the noise. I did some research online and this is what it seemed to be when the starter checked out. Got a call from the mechanic and they said they change the flex plate and the noise was still there. They then commenced to do a torque converter test by driving the truck like maniacs I guess. They said when they did this the last gear began to slip and then the truck went as if in neutral. They shut it down and started it back up and the truck would not move...in any gear. They concluded that the noise was the torque converter and now it had failed. Now I have bought a brand new AC Delco converter but I am not sure if this is really the problem. I could not have it checked by any other mechanic due to time, my job, and just the lack of good available mechanics. This is why I usually do all my own stuff but something like this I had no time to mess around with. I scanned the truck today with my ScanXL Pro GM enhanced license and no codes are showing up for anything. Now I need some advice or suggestions or anything. I really don't want to be throwing any more money at this truck as I already have more fixing it than what I bought it for. I had to replace the engine 6 months ago. I really love the truck but if its not the converter or something simple I'll just have to sell it as a loss and get something else as my job requires me to be highly mobile and it's been highly stressful trying to find alternate transportation for the meantime. I'll list some notes at the bottom whether related or not and hope you guys can help or guide me in some way. I have tools and am mechanically enclined to do troubleshooting that doesnt require pulling the trans.Thanks in advance.
-engine replace 6 months ago
-upon inspection starter only had one bolt holding it in and was slightly loose, nut on the other side was missing
-tranny filter and fluid changed 6 months ago
-engine oil replaced 1 month ago
-brakes replaced 2 months ago
-no shifting issues prior or up to when it went to the mechanic
-I have been on about 6 road trips during the last 3 months, most with hilly terrain
-noise was limited to bellhousing
-flexplate taken out was fine, no cracks or damaged teeth
-I had to driver through maybe 4-6 inches of flood water day or two before noise appeared
-throttle body cleaned week before
