Ok guys let's see if you all can help me out...that is if my issue is even a problem. From taking ownership of this vehicle to me my '05 Envoy 6cyl seems lazy from takeoff. Now I don't know if it's just how these vehicles drive but it's not something I'd expect. I could also almost swear that at some very rare times the vehicle does not have this issue. I don't think I'm getting crazy. I know one other member here described pretty much the same thing I'm experiencing. Nothing jumps out as being wrong with the vehicle. Below I will list everything I've done relating to the vehcile below and see what you guys think. Thanks.
Engine replaced with a lower mileage unit (original engine was blown)
Transmission replaced with a lower mileage unit (no difference)
Torque converter replaced with a brand new ACDelco until (no difference)
Transmission filter and fluid replaced (helped shift points)
Brake pads replaced and calipers serviced (no noticeable difference)
Tires kept at correct PSI (no noticeable difference)
Throttle body cleaned multiple times (no noticeable difference)
Spark plugs replaced twice with ACDelco Iridium (no noticeable difference)
PCMofNC tune (helped a little)
Removed 20" SS repos (helped a little)
Switched to Shell gas as this seems to be the best locally (only mpg seems to be affected)
*I do not keep unnecessary added weight and 98% of the time I'm the only occupant of the vehicle*
