Trans Fluid on back wheel
PDDavis1970
2
49419
Has anyone experienced Trans fluid spraying on driver's side rear wheel?
My wife has a 2006 Envoy with 4.2L I6. I found puddle in garage just in front of rear tire on driver's side. Thinking brake fluid, I pulled wheel off and found red fluid had sprayed on fender well and undercarriage at some point. I am not seeing any leaking but vehicle is not running.
The only fluids around there are brake fluid and fuel. Brake fluid is normally not red, even when dirty.
gpking
534
Berkeley Springs, WV
If you're positive it's ATF on that side, maybe it is coming out of the vent hose? The vent hose is directed to the driver's side. Don't ask me how I found that out without even looking.
Also, when one of my lines ruptured near the strut tower, it soaked the entire undercarriage with ATF. You might want to verify that is not the case either. That was not a fun job.
10,685
If we had an award for most surprising and improbable cause for an issue, I would nominate you sir. :tiphat:
33chevyrod
