Tinted Headlights
YOUNG
I have tinted my tails already and I have seen many people tint they're headlights, and leave the area clear(untinted) where the low and high beam show through. I was wanting to know how much the tint would effect the output of the lights if i were to tint the entire headlight. I understand the more coats = Darker the tint, and less light.
smitty5150
IMHO, it's just a bad idea to tint the entire light. It will either be too light to notice or too dark to be safe. Leaving the hi/low area untinted will at least preserve visibility, though you could still have inspection issues if your state is strict. If you want to do something like tint, I would recommend either something on the lighter side, or getting a second set so you can swap bac and forth if you need to.
JRTAHOE
848
This^^^.
That's what I did with mine
Short Bus
1,906
:iagree: with Smitty and Rider, but if you want to try it why don't you use the tint film you can get on ebay so it's easy to go back to stock?
[EBAY]310351895002[/EBAY]
I was a broken record on this issue on the OS, but then I'm an old fart who just doesn't "get it". Why in the WORLD would anyone trade safety for the illusion of some sort of better "look" if it wasn't a trailered show poodle of a truck? :confused:
JRTAHOE
848
That's why I only did part of my head light. Even with HIDs, it seem like a horrible idea.
smitty5150
I took mine apart, painted the bezels, and tinted the corners. "OEM" for the sake of state regs, safe to drive on, and about as custom as you can get. Probably going to do a projector retrofit over the remainder of the winter, now that I have a junker set to drive on. Down time is a bitch.
gmtrailblazer
62
I tinted all of mine except for the low/high beams also. I definately would not recommend tinting all of the light though.
ieatglue
152
I personally love the yellow corner markers and turn signals. I even swapped out the yellow parking lights with darker orange ones. Looks 1000% better IMO. Just another option
YOUNG
I agree with all of you, but i was wondering if anyone ever did the whole light, we dont have inspections here in the rural parts of TN. And ive seen a few trucks with the whole headlight tinted, and i wasnt sure how well they could see..
i plan on tinting my headlight like many of you have leaving the low and high beams exposed.
07 TB RIDER said:
this is what i will probably end up doing. really dark tint, so it will match my black grill crossbar.
Boricua SS
3,080
i agree with everyone else... just a waste of time... for all that, why not just get a headlight cover that you can take on and off? but even that will look dumb IMO..
i understand the idea... but as roadie said, why sacrafice safety over visual effects...
YOUNG
i understand that it would darken the lenses, so there would be less light output, but i was wondering how much less it would be.
10,798
The answer to your question depends entirely on how fast you sprayed, and how many coats.
:lightbulb:What you could do, is get a can of Niteshades, and then take an empty clear plastic container, and spray it. Hold it in front of a light in your kitchen and see how much less light gets through. Seeing for yourself would be a much better way to answer your question, rather than a bunch of other people trying to convey their own perceptions. :twocents:
YOUNG
see that is a good idea! :wootwoot: im going to have to try that, i could bet a small storage bin with a flashlight behind it would work pretty well..
Edit : or even holding it right up to my headlight might work, but im not sure.
Boricua SS
3,080
its kool man... it was just my opinion.. i wouldnt sacrafice safety.. but im me and you are you...
but i do like Carlton's idea, just make sure you test things out.. would hate to see something happen over a mod ya know...
JRTAHOE
848
I assume headlight covers and tinting your whole had light is roughly the same shade of darkness.
These are from back in the say when I used to run them.
JRTAHOE
848
YOUNG said:
how much difference in light output did u notice when u had them installed? was it a huge difference?
It kind of sucked with stock lighting but it did get a little bt better when I got 6000k HIDs even though with the covers on, it gave off a greenish light. :confused:
YOUNG
yeah i dont have hids yet, but i have hoens low and highs, and they are just as bright as most peoples hids. IMO.
i might be tinting the whole thing :tongue: but im not sure yet, ill be considering different things the next month or two, and then tint when it gets warmer.
YOUNG
here we go alot of pictures, but im a visual person and i just like pictures!
weather finally warmed up, and i didnt have anything to do today. So i went ahead and tinted the Headlights! :biggrin:
These have about 6 or so good coats on them, and 5 heavy coats of clear.
Taped up, ready to paint.
Coat 1 Light coat
Later Coats, Thicker coats.
drying up
Tape Removed :biggrin:
ItsOnVoy
2,401
Didn't you have a black cross bar? :confused: Or did you change that or something? Also how do those turn signals show with that? I would have not tinted the turn signals! That can cause a head on accident if someone does not see you going to the left lane as they are also because there turn is the your right just before it or something. Happens to me sometimes and that turn signal saves my ass every time :yes:
Voymom
2,523
I agree with not have tinting the signals. I did my side view mirror signals and they look good but DARK, I don't think they are dark enough for LED's but I have not been in it at night since. And I probably won't for a while. I plan on ruining my headlights lol by tearing them to shreads to paint the little chrome insert things instead of VHT on the headlights. I hope this makes sense...been doped up since my surgery yesterday :smile:
jrSS
Yea good luck with the headlights
Voymom
2,523
I'm gonna make hubby do it so I can't be blamed for killing em lol
Short Bus
1,906
Looks good :thumbsup: How about night pics with the parking lights on.
10,798
ItsOnVoy said:
Didn't you have a black cross bar? :confused: Or did you change that or something?...
:undecided: I thought the same thing, glanced at the avatar to make sure the booze I was drinking wasn't making me see things. :laugh:
My suggestion, paint the gray mesh of the grille, and the bowtie, gloss black to match the tint of the headlights. :biggrin: :cool:
YOUNG
Yes my grille used to be black! i stripped the paint off it about a week or two ago when i got the truck back from insurance..
Im repainting it probably tomorrow.
im debating leaving my bowtie as it is (goldish close to paint color) or paint it black to.
My headlights are very dark, the turn signals on the front show through nice and red though, and i like it, not nearly as good as stock. but you can see it blinking. I will be looking for leds or brighter lights, so if anyone has any ideas of lights, post them up!
I will post pictures at night tomorrow night, as ive already taken my lights back off for the night to sand them down and everything. yes those are pictures of non-sanded lights. all i did was remove the tape.
10,798
If you're gonna paint the crossbar again, then yeah, leave the bowtie as is :yes:
Switchbacks. Get some! :biggrin:
ItsOnVoy
2,401
:iagree: Or you can color match the bar and paint the bowtie black! That would look good :yes:
:rotfl: How did I know this was going to the be the next post :raspberry: lol
But yes switchbacks are deff worth it and look good!!
smitty5150
Definitely dark! Looks good, though. I would be inclined to use those as show lights. Curious, how did you prep them? These lights see a lotion abuse. I have seen some professional sprayed headlights peel because of ruhed work. They are not easy to strip back.
YOUNG
not much prep :lipsrsealed:
I washed them with warm water, used a sponge and cleaned them, no soap or anything, and just sprayed them off in the sink, took them out and dried them with a microfiber cloth and then didnt touch the sufface. Then taped them up, wiped them down with a dry microfiber and then sprayed them, waited 20 mintues or so between each coat, and then sprayed again.
sc repair
Staff Online
