I may just do the LCA brackets, since that's where the bushings are. And since I haven't been able to get the links off, so I figure the bit that holds the ball joint is stuck on the vehicle until I figure that out.
I was happy with the driveability upgrade when I did UCAs to get new bushings there. The UCA itself was perfectly good, I just wasn't going to press in/out the bushings, though I found a machine shop recently that would do it I bet. I went with Dorman , but they don't make a much simpler part than a UCA, so it would be tough to screw it up. And they were cheap.
Mevotech UBJs ... I tought the rubber boots failed pretty fast. I have replaced one of those with a Napa. Maybe I'll just replace the boot on the other one, if it seems like the joint is still working properly. When I first put the Moevotechs on I replaced a ball joint that didn't have any play in it just to do both at the same time, and now I think that was a mistake, especially to replace a functional part with a cheap replacement.
The middle part of the LCA ought to be pretty solid, too. Rusty, but perfectly good.
