Supersparkz Review
03envoy
537
Well I have recieved my "Supersparkz" from 06Envoy, Thanks! I have installed them and plan to test them out for a week or so. Then maybe pass them on. So far, I havent driven it yet. I did do an idle test (showing RPM's). I cant get the stock video off my camcorder but, I will get a stock video. I do have a video on my other camera of after. Its a startup of the envoy.
IDLE:
I did NOT notice a POSITIVE change in the idle. So far my idle has gotten rougher at around 700RPM's. I get a slight "shake". There is no sound difference. I will update as I go along! Thanks!
Video with Supersparkz:
Sorry for the quality
[video=youtube;A4btjuoi43A]http://www.youtube.com/watch?v=A4btjuoi43A&feature=youtu.be[/video]
update 4/21/12
Well today I drove the truck around a Little bit, Nothin Far. At normal speeds between 40-50mph, I was getting a "Surge" of some sort. As I let off the gas, and was coasting it felt like the engine was surging. I havent changed anything other than installing the Supersparks. I didnt get any codes. Could Misfires possibly cause this? What could cause that? I am sure it wasnt the rode because I did it on two different roads.
Note: No change in RPM's, All gauges looked normal.
update 4/28/12
I have had these supersparkz on for about 2 weeks now. I have noticed a negative affect on my truck, it just doesnt like them. I have no codes, but I am getting a noticable vibration and am still getting a small surging. I think its in the best of my interest to pass them on and see how it does in another vechical. I wish I could write a good review but, I am not going to risk an issue that may occur when using this homebrew crap.I just dropped $450 on front struts to be installed, and If something were to go wrong I wouldnt have a vechical. I am sorry and I hope somebody else can have better effects than mine. Thanks.
update 4/29/12
I just took out those POS Supersparkz. Omg what a difference! The idle is a ton smoother without them! I have no Noises like the "Piston slap type noise I was hearing. Drives like a beauty.
Overall Review: DO NOT BUY! They may cause a rougher Idle, Surging at speeds around 40mph and Noises similar to a Piston Slap!
03envoy
537
MAY03LT said:
Glad to see that you're following up...respect!!!:thumbsup:
Thanks! Your videos have helped me out ALOT! I just need to get this damn video off of my camcorder.
Any suggestions that you want me to do with them installed?
MAY03LT
Delmarva
Right on man!!!
In the other thread, people were talking about idle, random misfires, power, and mpg's. So I would say drive the truck normally and see if any of those things are better/worse.
03envoy
537
MAY03LT said:
Right on man!!!
Ok Thanks!
RayVoy
939
03envoy said:
IDLE:
Just so we can get a somewhat scientific test here, we need to state a few basics.
Did you disconnect the battery while installing the supersparkz?
I'm asking, because clearing the "learned" programming in the pcm will skew the results (maybe the reason for the roughness at 700rpm).
06Envoy
Good to see that you got them ok.
Did the uneven lengths throw you off? Any problems installing them?
Also just to clarify to everyone, he received them as I did. In the original baggy.
He was the first one to install them, I never did.
When your done with them, there is another fella here who PM'd me and would like to try them.
EDIT: Unless they blow your mind and you want to keep them of coarse! :raspberry:
Short Bus
1,906
Are you sure you have the correct size? IIRC 02-05 and 06+ are different.
06Envoy
Good thinking, but no worries.
I bought those for my wife's truck which is an '04.
He should be good to go with his '03.
03envoy
537
Yes, I shut the hood and forgot to connect it:lipsrsealed: Then connected it and started it up!
And PCM scan data of things like misfires, fuel trims, and so forth would be acceptable data. Claims of butt dyno improvements will be viewed with skepticism.
03envoy
537
No. I just put that longer one in cylinder two so it was easy to get at. That's fine if he wants them, but I want to atleast keep them for a couple weeks so I can really see if they do a thing. If you don't mind? If I do like them, I will still send them to him and I will order my own pair! :biggrin:
03envoy
537
Agreed. Can an OBDII do that?
03envoy
537
Well I cant Edit my first post, but I will just add Information as I go.
RayVoy
939
Well, here's the problem, and probably the source for the surging. Before you started the project, the PCM adjusted it's self to your way of driving (the "learned" reference in my previous post), when you disconnect the battery, you removed all of those "learned" adjustments, along with any adjustments for things like a dirty throttle body.
I am afraid, that anything you feel/see/hear in the way of a change, will be because of the battery disconnect and not because of the supersparkz.
The "better" test would have been to not disconnect the battery.
My 2 cents, would have you go back to the oem equipment, clean the throttle body and drive for awhile (time and distance depends upon how you drive), then change to the supersparkz (without disconnecting the battery) carry on with the comparison.
03envoy
537
Hmmmm. :undecided:
Once I get the time I will do. I am not going to rush this. So I will do as stated and then Drive the truck regularly for approximatly a week or so. Then I will switch back to the supersparks, Without disconnecting the battery? Correct?
RayVoy
939
03envoy said:
Hmmmm. :undecided:
Once I get the time I will do. I am not going to rush this. So I will do as stated and then Drive the truck regularly for approximately a week or so. Then I will switch back to the supersparks, Without disconnecting the battery? Correct?
Yep,,,,,,,,,,,,,or, just leave it alone, drive it as it is for a few weeks, Do not try to compare it to the way it use to drive.
After a couple of weeks of driving (when the "learned" adjustments are re-established, start your notes. This is your starting point.
Take notes for a couple of weeks.
Change back to the oem conductors (without disconnecting the battery) and continue the notes and the test.
You would be comparing the original to the supersparkz, instead of the other way, but that will work :thumbsup:
03envoy
537
Gotcha. This way seems better. I will start! lol Thanks!
03envoy
537
MAY03LT
Delmarva
I copied your follow up posts into the original post so everything is right there.:cool:
03envoy
537
Thanks man!
06Envoy
Yup. There is another fella waiting to try them. PM sent.
Thanks for the reviews!
Chickenhawk
782
Please continue your review after you have removed them and let us know what happens.
To be scientifically valid, a product would have to show a certain effect once installed, and then return to the previous state once removed. Please let us know if the vibration you experienced disappeared after you removed the Supersparkz.
03envoy
537
Will do!
03envoy
537
Thanks,
Trent
At the risk of you flying to San Diego and slapping me, to be DOUBLY certain, you have to put them back in and take them out again and repeat the experiment.
Or you can be a believer like me that there is a lot of snake oil in the world and people just make shit up to sell it.:wink:
03envoy
537
What bullshit these are. Man that pissed me off. But, Yes Roadie I learned from my mistake of even thinking these would work!:duh::hissyfit:
fadyasha
1,134
Strange you're having all these side affects buddy! I haven't experienced any of the symptoms you've had! I had a slight improvement at the beginning but now it's more or less the same as before. I'm keeping them for now, but for the heck of it during my next spark plug change i'll swap back to the springs. No real value from them anyways! :rotfl:
06Envoy
Is there anyone else who would like a shot at them?
(Here's looking at you Roadie!)
The next person who was inline to test them PM'd me and declined. Not to sure that I'm surprized really.
  • A_Cartoon_Man_Being_Shot_Out_Cannon_Royalty_Free_Clipart_Picture_100509-137682-795053.jpg
06Envoy
Here's what I'd do with them:
Ya but, but, but!!!
Who better than you to scientifically test these things.
You'll be skeptical (putting it mildly) to be sure, but You'll be honest and thorough.
And that's what this product needs.
Heck GMTNation.com could be the site to prove either way and we could be linked to other sites where the vender is peddling this product.
What say you?
06Envoy said:
What say you?
I have a bit too much stuff going on at the moment I can't even BEGIN to list, but it involves working about 75 hours a week, flying to Korea on Saturday, driving my wife to work every morning with her broken ankle, and so forth. I haven't even driven the Roadiemobile in 3 weeks. That sort of stuff. :lipsrsealed:
So I have to decline. :frown:
03envoy
537
Busy man! :eek:
06envoy,
I was just going to put up a post asking if anybody else wanted a shot!:crazy:
03envoy
537
Yea, I could instantly feel the change once I switched back!:eek:
It was a Pain in the ass to get that first cylinder coil out! Twice! Lol
06Envoy
03envoy said:
...I was just going to put up a post asking if anybody else wanted a shot!:crazy:
Sure! So if anyone wants to try them out and post up your results, please speak up!
03envoy did a great job of keeping the reviews honest and informative. That's all we are looking for from the next reviewer.
Remember these are free to you. If you like them, keep them! If you don't like them, just pay the shipping to the next guy. Simple right?
And remember to post up honest results. :thumbsup:
03envoy
537
Thanks, Tomarrow just to add to it, I will post a cold start without them to compare too the video posted before.
Yep, always looking for another opinion!
McGMT
621
Ok, so I know this is a little old of a post and all, BUT I really wanted to say something about these things because I had looked at them before myself... Ok, bear with me because this could get a little long winded and if your not a real electrician you might just want to skip to the end...
We all know there are regular spark systems and resistor type. Ok, well, the stock setup is a wound coil "spring" type of connection. Anytime that you coil (wind up) any type of wire you create a self inductance in the length of wire, depends on the length and tightness of the coil itself. Self inductance is a wire creating its own current from the magnetic force generated between each coil. This current created effectively goes backwards thru the wire counteracting the applied current put to the wire. So, in other words a coiled wire like this is a crude resistor.
A good example of this being used for a real purpose is the ABS system on GM vehicles (At least in the past). The wires coming from the WSS's (+ & -) were twisted, or coiled together. This created resistance in the wire itself. When serviced, these wires had to be rebuilt including the same number of twists as was put in it from the factory or it would fail its self test and set a code with the EBCM. Check out a TSB or GM repair manual on a mid ninetys passenger car, it will tell the tech to make sure there are X number of twists in the sensor wire.
So to sum it up, the absence of this resistance more than likely screws with the coil or the PCM. So just don't do it, its junk made by someone that thinks a solid connection is better and doesn't understand electricity....
Now, if you will excuse me, I have to go and stretch my fingers... :yes:
ramblinjon
