NEED HELP Strange whining noise.
VoyNali
Virginia
Afternoon all. I have an 07 Envoy Denali that I’ve owned for 10 years. The vehicle had 98,000 on it when I purchased it. It now has 205,000. I replaced the engine and torque converter, after lifter failure, at 138,000. Not fully understanding the pitfalls of the “Absolute Friggin Mess” these engines were designed with, I opted to replace it with another AFM remanufactured Jasper which did the same thing again at 158,000 (warranty covered this with an AFM unit again). I finally decided to research the AFM issues (better late than never?!?). I had the AFM disabled with an HP tuner at approximately 181,000. This is not my issue, just a little backstory first.
The issue: ever since I’ve owned the vehicle there would be times when I would first take off that the vehicle sounded like a dump truck or 18 wheeler starting off and felt like it was struggling to move out of 2nd gear. This would subside after a short period of time and it would run fine. However, I recently had someone perform a Dyno-tune on it a couple days ago and now this seems to be the prevalent sound the vehicle makes once it’s warmed up. This happens taking off from stop lights, accelerating while already in motion or, at almost any point - not always continuously, but enough. I’ve checked the fan clutch, which seems to be fine. I’ve read that this can be a reason - pulling power from the overall drivetrain.
There is no overheating, no DIC notices, no codes. After the Dyno-tune and test drive the engine recorded 200 temp and trans was at 158. I am prepared to rebuild/replace the transmission if necessary. I assume the transmission has the same 205,000 that the vehicle does. I have changed the transmission fluid and filter 3 times since I’ve owned it. I also replaced all trans solenoids on last fluid change 3 months ago.
Any suggestions or advice would be greatly appreciated. I am not a DIY mechanic. I am a retired carpenter.
I honestly don't know. It could be a defect or a failure that's been there since day 1. I thought maybe it's something with the tune but you say this has been happening since you've owned it. It might be time to take it to a tranny shop.
I posed your question to AI and it kept coming back to the fan clutch:
The "dump truck" or "18-wheeler" roar paired with a sluggish sluggish takeoff is a classic combination of two separate, interacting systems on your GMT360 Envoy Denali: an over-engaged electro-viscous (EV) fan clutch and a transmission torque management / shift mapping adjustment introduced during your recent dyno-tune. [1, 2]
Your transmission is not necessarily failing internally right now. Instead, the dyno-tune likely altered parameters that are causing your mechanical fan clutch to lock up aggressively and stay locked up, mimicking a transmission slip or severe mechanical struggle. [1, 2, 3]
1. Identifying the "Dump Truck" Sound​
The literal roaring sound that sounds like a heavy commercial truck accelerating is the engine fan spinning at full crankshaft speed. [1, 2]
  • The Culprit: The 2007 Envoy Denali uses an electronically controlled, viscous fan clutch (EV clutch). The Powertrain Control Module (PCM) dictates exactly how much the fan engages by pulsing a command signal.
  • The Parasitic Draw: When an EV fan clutch locks up fully, it acts like a massive mechanical brake on your engine, sapping up to 25–30 horsepower. This massive power drain makes the vehicle feel incredibly heavy and sluggish off the line, giving you the sensation that the transmission is struggling or failing to shift cleanly out of 1st or 2nd gear. [2, 4, 5, 6, 7]
2. Why the Dyno-Tune Made it Worse​
Before the tune, the fan clutch engaged intermittently. Now it happens constantly once warmed up. This occurs because of how tuners modify tables in GM’s E38/E40 PCMs: [2, 8]
  • Altered Fan Target Tables: Tuners frequently lower the commanded engine coolant temperature (ECT) thresholds in the software to make the fan engage much earlier and more aggressively to keep dyno temps low.
  • The A/C Pressure Link: The fan clutch command responds directly to air conditioning high-side pressures. If your tuner adjusted the fan maps or if your engine bay temperatures are triggering higher pressures, the PCM will command 100% fan lockup continuously.
  • Torque Management & Shift Timing: Tuners often remove GM's factory "Torque Management" (which pulls engine timing during shifts to protect the transmission) and modify shift points. If the transmission shift points were altered but the engine is bogged down by a fully locked fan, the 4L60E/4L70E transmission will feel confused, delayed, or overly harsh when trying to execute the 1-2 or 2-3 shift. [2, 8, 9, 10, 11, 12]
3. Step-by-Step Diagnostic Plan​
To isolate the issue without prematurely tearing out a transmission that has been well-maintained with three fluid changes and fresh solenoids, follow these steps:
Step 1: Scan Live Fan Data​
Do not just look for diagnostic trouble codes (DTCs), as a misbehaving fan clutch map will not throw a code if it is doing what the computer tells it to do. [1]
  • Connect a live-data OBD2 scanner while driving the vehicle warmed up.
  • Monitor Commanded Fan Clutch Speed vs. Actual Fan Clutch Speed.
  • If the commanded speed is high (e.g., above 50–80%) at a normal operating temperature of 200°F, your tuner programmed the fan to be hyper-aggressive. [2]
Step 2: Test Drive with the Fan Unplugged​
To verify if the transmission is actually slipping or if the fan is simply choking out the powertrain:
  • Locate the electrical harness routing to the fan clutch shroud and unplug it.
  • Take a short, gentle test drive around the block from a stop light. (Keep a close eye on your temperature gauge so it does not overheat).
  • The Verdict: If the "dump truck" noise completely vanishes and the vehicle shifts beautifully through 1st, 2nd, and 3rd gears with its normal historical power, your transmission is mechanically fine. The problem is entirely software-driven or a physically binding fan clutch. [4, 13]
Step 3: Check for Mechanical Fan Failure​
Viscous fan clutches can fail "locked" mechanically if the internal fluid thickens or a valve jams. [14]
  • With the engine completely off, try to spin the fan by hand.
  • It should offer smooth, firm resistance but spin. If it is completely frozen, or solid as a rock when hot, the clutch itself has failed mechanically and needs replacement. [8, 11]
Summary Recommendation​
Before spending thousands on a transmission rebuild, return to your dyno-tuner. Show them this behavior and ask them to look at the Fan Duty Cycle / ECT tables and AC pressure fan request tables in the tune file. Request that they roll back the fan engagement aggressiveness closer to stock parameters. [2]
If you decide to proceed with looking into the health of the drivetrain, let me know:
  • Did you notice any RPM flare (slipping) between the shifts when the noise happens?
  • What specific brand or style of fan clutch is currently on the vehicle (OEM or aftermarket)?
  • Do you know if your tuner adjusted the transmission line pressure or shift points during the dyno session?
I think the points and questions it posed are pretty on point.
Mooseman… thank you for the insight. All of what you stated and discovered makes perfect sense and agrees with my initial research and ultimate findings as well. The only difference being that this Envoy has an E67 PCM.
I did, out of a sense of urgency, take it by an automatic transmission shop after I posited this inquiry. They were scheduled out till the 2nd week of June… I pressed the matter somewhat, receiving a rather flustered yet agreed to test drive by the shop owner.
I rode along with him. He did accelerate and drive it pretty aggressively, I assume to check for slippage. His conclusion: Fan Clutch!
I took it to my “regular” mechanic, it is scheduled to have the fan clutch replaced next Wednesday. I am also having a transmission cooler installed at the same time. I will return here to reveal the final results upon completion.
Thanx again for your prompt reply. Much appreciated.
If your tune also included a delete of the codes for the EV fan clutch, you could get a regular thermal clutch for a 2008. The EV clutches are so bad that even GM went back to the old fashion thermal clutch in 08. If the tuner is local, maybe he could redo the tune to turn those codes off.
Gustavoc100
