Afternoon all. I have an 07 Envoy Denali that I’ve owned for 10 years. The vehicle had 98,000 on it when I purchased it. It now has 205,000. I replaced the engine and torque converter, after lifter failure, at 138,000. Not fully understanding the pitfalls of the “Absolute Friggin Mess” these engines were designed with, I opted to replace it with another AFM remanufactured Jasper which did the same thing again at 158,000 (warranty covered this with an AFM unit again). I finally decided to research the AFM issues (better late than never?!?). I had the AFM disabled with an HP tuner at approximately 181,000. This is not my issue, just a little backstory first.
The issue: ever since I’ve owned the vehicle there would be times when I would first take off that the vehicle sounded like a dump truck or 18 wheeler starting off and felt like it was struggling to move out of 2nd gear. This would subside after a short period of time and it would run fine. However, I recently had someone perform a Dyno-tune on it a couple days ago and now this seems to be the prevalent sound the vehicle makes once it’s warmed up. This happens taking off from stop lights, accelerating while already in motion or, at almost any point - not always continuously, but enough. I’ve checked the fan clutch, which seems to be fine. I’ve read that this can be a reason - pulling power from the overall drivetrain.
There is no overheating, no DIC notices, no codes. After the Dyno-tune and test drive the engine recorded 200 temp and trans was at 158. I am prepared to rebuild/replace the transmission if necessary. I assume the transmission has the same 205,000 that the vehicle does. I have changed the transmission fluid and filter 3 times since I’ve owned it. I also replaced all trans solenoids on last fluid change 3 months ago.
Any suggestions or advice would be greatly appreciated. I am not a DIY mechanic. I am a retired carpenter.
