Service Stabilitrack and ABS light on....
joemcc
23
Well, what are the steps to solving this.
The lights came on last week and off...then back on today.
NOTE: got new struts and alignment recently too.
Joe
mrphoenix80
251
Have the code checked it will tell you where to look! But in the mean time check the electrical connectors for the front speed sensors and make sure they are seated fully. If you just did struts then I would look for something loose. If a visual check does not show you GET IT SCANED. There are to many parts that can cause these lights to just guess and throw parts at it. Diag is cheap conpaired to the cost of "Oops, well thats not it. Lets try something else".
joemcc
23
Thank You! the guy that did the struts
has a scanner and said he will check it out for me..... no charge.
joemcc
23
Right front speed sensor.......
Should I replace it or the whole hub assembly?
joe
Chickenhawk
790
It's almost too much of a coincidence that struts were just done and now the right front speed sensor is out.
The wire is easy to inadvertently break when replacing a strut.
When you say you just had the struts done, did the light come on an hour, day, week or month after the work?
joemcc
23
it was about 3 days after. it might be worth mentioning it comes on when I hit a bump and then usually goes off at some point during the day. just to come back on at the next bump.
sc repair
