A Few Scenarios for Probable Causes of the P1682 Code:
(1) A Fuse Contact Issue:
Notice the Dirty Conditions of the Uncovered Fuse Box as an invitation for Electrical Problems caused by the invasion of Dirt and Junk into the Fuse Insert Points making for Very Sketchy Electrical Pathing:
(2) A Broken Harness Wire 'Twixt The Fuse Box and The PCM:
On the chance that you are looking for a Broken Harness Wire, this Video should prove helpful with Solving the Code P1682 Problem. Follow the VOP's (Video Original Poster) Step-By-Steps He used ALLDATA Diagrams here and watch him conduct some logical diagnostic steps to achieve this Repair:
Please take note of just how THIN & Fragile the Wiring in those Harnesses can be and know that the Ordinary Engine Gyrations of the Engine's Rise & Fall of RPM and Torque while riding upon Bad Motor Mounts can invite problems of having Hidden Broken Wires like these.
3) Replacement of the Fuse Block SOLVES the P1682:
In an Alternative Scenario, "Terry" provides us with a pretty lengthy description of what lead him to Replace the Entire Fuse Box (Panel) in his Performance LS Flavored Trailblazer and solved his P1682 Problem:
If there are any differences between the Wiring Harnesses and Connectors for Non-P-10 PCMs and your present PCM, I'm dropping a Link below, so you can view the 'Old Style" PCM Connector Pin-Out Diagrams. Just follow the VOP's Procedures, but use the more Relevant Wiring to Pin-Out Diagrams instead:
Check Out Post #4 HERE for the PCM PIN-OUTS:
Looking to pick up on the reverse lamp circuit at the BCM. I've found sources that indicate it may be a light green wire, but there are several of them back there. One of which is a com wire that didn't take kindly to having a test light on it... anyone have a pinout for the connectors or a...
gmtnation.com
Also... Check Out
THIS Thread
(Courtesy @Realism) for the Engine & Body Grounds and Bonding Strap Locations:
While troubleshooting a bad ground I came across some scans of the service manual regarding electrical ground locations for our platform posted on another site. This includes both short and long wheel base, as well as both 4.2L and 5.3L. Credit goes to Wex...
gmtnation.com
