Update... the engine from the 05 Trailblazer ran very well in the buggy. Great oil pressure. No leaks. Good water temp. So it’s going in an 05 Envoy
On a previous update I showed pulling everything out if the Envoy together. Now it’s time to put it all back in. It went in easier than it came out. The key was finding the right angle on the hoist using straps and chains. Once it was in the engine bay I put the end of the transfer case on a jack to slide it in. I had to rest the oil pan on the front so that I could readjust the chains on the engine hoist. I was hoping at that point I could install the intake manifold but there just wasn’t enough room between it and the cowl.
I did it all with the tires on the ground. I thought I would have to remove the driver side engine mount but the differential just barely cleared. I did remove the two rubber mounts to make room.
the worst part is over. Wrestling around under the vehicle lining up the exhaust and transmission mount. Today is filling the fluids and attaching everything to the engine which I’ve done numerous times thanks to practice using the test buggy.
