Quick Reply
Regulator
How about getting a quick reply box at the bottom of the thread?
I like the qucik:raspberry: idea.
There was a good reason why we never did it on TV..... I will be damned if I can remember what the reason was though.:undecided::undecided: Jimmy or Joe will probably remember.
Definitely I would like it, if it could work out.
I might be able to accommodate this request, but it will take some special coding to make it a user selectable option. I don't want this active by default, but for those that want to use it, I should be able to add an option to your user control panel that will allow you to turn it on.
I will not be able to work on this until the second week in December.
Take your time man! You have a lot on your plate and we all appreciate all the hard work your doing :hail:
Jimmy, we do appreciate all you are doing and will be working on over the next several months. So far so good!!! Everything is coming together very well!!!!! :biggrin:
:iagree: For real man, you're putting in a ton of hard work. Since you're in the neighborhood, you'll have to let me buy you a beer sometime
I can definitely relate to all of the work you are putting into getting this up and running. You are doing a great job at it.
Just to clarify... That is going to be the second week of December of this year? :tongue:
Is Quick Relpy anything like Instant Messaging?
There's a quick reply box already active for the PMs here, as well as PMs on the OS. The PMs auto quote, I'm assuming for a thread reply they wouldn't quote anything? :undecided:
if it will be like anything on the other sites i belong too, its just a box at the end of the current page that allows you to post your reply there instead of hitting the reply button, then going to the next window, etc... its just a faster way to reply to a thread your in...
and the forums im on that have option, you are correct carlton, you cannot quote anyone in a quick reply...
I love the quick reply feature on the GMI forum. I'd love to have it here!
If you were to use the "Multi-quote" button, you would be able to quote people in the quick reply box.
I plan to make it an option for users to enable, but I need to modify some code. I won't be able to get to that until next weekend.
ah ok.. gotcha boss... take your time man... thx for a great site...
Take your time man! You've done a great job with everything! :smile:
nickG
