well since I was playing around in the "front end" with the replacement of the alternator, I thought perhaps I would continue trying to track down the "noise" up there. Some of the noise may have been contributed by the old alternator and possibly the idle pulley (also replaced). Noise is lessened but still not good. While having the belt off, ran the engine a bit and things seemed "more quiet", so somethings up there. Anyways, I was going to drain some tranny fluid and "refresh" as trailer hauling (at peak load capacity) is probably a good "life shortener"...
Anyways, decided to look at the power steering level. Looked good cold. No change in noise with movement of steering, steering effort seems fine. Anyways, my eyes don't look so good any more ... so I decided to draw out a sample of the fluid with a thought of a "refresh"... I know a flush is the right way, but that's whole new "effort" and likely new story as playing with any of the lines will likely result in replacement as the 200kkm haven't necessarily been kind to a few things in terms of rust... :-(
Anyways, I was surprised at the "draw out"... YIKES!!!! Now I am likely into it... :-(
The "stuff" doesn't look like any power steering fluid that I have ever seen. I don't think its tranny fluid (I know I have never put any in... clear power steering fluid for topping once).
I can't say that I was overly observant at the dip stick "coloring" at the time of checks... more with where the "wet mark" was as opposed to color.
So here I sit. I am thinking I will draw out as much fluid as I can, replace with new one, do some wheel turning (off the ground) and do another "draw and replace" for now. I guess my question is: am I actually doing anything for the system or is it beyond "reproach". :-(
Other suggestions or comments on what's going on... :-(
