Short Bus said:You better use a relay harness or bad things will happen.
Ghost said:Do you mean upgraded wire harness ?
RedEnvoyDenali said:What he means if you try to run 100w bulbs drawing about 8 amps, where the harness was designed to run 55w bulbs drawing about 4.5 amps you will fry the wires. That is why the audio guys run super huge cables because they draw a horrendous amount of AMPS. Now if the bulbs only say 100w but draw 4-5watts then your OK but your only putting out
55 watts.
HARDTRAILZ said:Cant wait for pics
Ghost said:Here is a recent photo of my ride...at Point Magu.
Here is the hi and low beams running unfortunately the Droid X doesn't do justice with the light output or color.
Canadian Mike said:I see photobucket placard, but no photos.
Short Bus said:A harness like this is cheap insurance against frying your wires.
[EBAY]320914141213[/EBAY]
Ghost said:Hello.
You mean like this ; ???
NOKYA HARNESS 9005/HB3 X 2 WIRES NOK9115 STAGE 2 UPGRADE HIGH WATT HEADLIGHT 12V | eBay
Short Bus said:That one only upgrades the wire for the last few inches. You'll still be drawing full power though your OEM harness. The relay harness just uses the oem harness to control a switch and draws power from the battery through heavier wire. IMO you need the relay harness.
If you don't want to wait for one to come from china, this one will work
[EBAY]190645290341[/EBAY]
Ghost said:Just purchased the philips rally 100w off road bulbs 9005 for the hi beams. Ill post pictures once they arrive. My 100w yellow's vs philips 100w rallys.
06Envoy said:Sorry to bother you. Can you post up a link on where you bought those bulbs? I can't seem to find them online.
I'd like to try out a set or two.
Thanks.
Ghost said:Ebay. Just type: 9005 philips rally.
I am a eBay junkie !
Thanks.
06Envoy said:Excellent! Thanks guys!
I just grabbed a set. I didn't know these things existed!
