InsaneOctane
- Joined
- Jul 2, 2015
- Posts
- 28
So now the first 10% of my pedal is a dead spot. This is a new APP sensor, along with the new TPS.
Before or after fixing the wire? If it hasn't been done since the fix, I would redo it.InsaneOctane said:I tried that and the reset gmcman said to do.
Is this the pcm reset sequence?gmcman said:Double check the TB harness, use some electronics cleaner on the terminals, make sure all the pins are in their proper position.
Pull fuses 10 & 28 for about 10 min.
Turn key to ON with all the dash lights on. DO NOT START AND DO NOT TOUCH GAS PEDAL. TB will perform series of noises during this time.
Leave key ON for about 5 minutes. DO NOT turn key off. DO NOT turn key off for the duration of the relearn
Start engine, DO NOT TOUCH GAS PEDAL, let idle for about 8-10 min.
Once engine has fully warmed, idle should settle around 600-625RPM. Generally under 650 RPM.
