- Jul 2, 2015
- 28
Ok so ive been getting a p1221 code. I got a 02 envoy and its slow to crank at times (mostly when cold but sometimes when hot) and bogs down a little every once in a while when you hit the gas but not always. Just replaced the TB and still getting symptoms but the code hasnt popped up yet since the system hasnt cycled. Any ideas? I know the fan clutch can throw the code but i wouldnt think itd have the symptoms. It also goes into limp mode every once in a while but shutting off and back on fixes it. also i took a test light to the connector and only two of the eight prongs lit up. not sure if thats normal or not but i thought id include it
