@xavierny25 Ha....still had a ways till the light kicked on....
Brief recap...I used the Glow Shift Digital Dual Temp and Pressure Gauge.
GlowShift’s Dual Digital Temperature/Pressure Gauge combines multiple temperature and pressure readings into one easy-to-use gauge for cars and trucks.
www.glowshiftdirect.com
With the Glow Shift Sandwich Adapter
GlowShift Oil Filter Sandwich Adapters with a 13/16-16 Thread Make It Easy to Install Oil Temp and Pressure Sensors Using the Oil Filter Mounting Location.
Banks Power 52MM Single Gauge Suction Mount
Sticky suction cup for windshield or dashboard useUniversal suction cup mount designed to work with the iDash and other 52mm (2-1/16 inch) gauges. Adjustable arm for a wide range of mounting angles. U
www.bankspower.com
I used my swivel dashcam mount that attaches to the pod of the Banks unit but I cannot find a link for it at the moment. This gave me more flexibility in mounting position.
The power wires are easily dropped behind the side pillar, but the sensor wires needed to be pulled up by taping them to a length of speaker wire.
Sensor wires taken through the firewall near the brake booster. Drilled 1/2" hole and used a 3/8" ID grommet.
Was easier to insert wires into grommet first then get the grommet seated,.as the connectors are 3/8" across.
Zip ties on both sides after you get the length set on each side of the firewall. This way you can apply some silicone to the wires and it won't pull the sealer through.
There was just enough wire to reach the gauge allowing a few extra inches tucked away if you need to move the gauge, as well as snake cleanly along the existing looms.
Sandwich adapter:
Sensor wires had just the right amount of length.
I'm glad I didn't use a dial gauge as the pressure ranges from 14 PSI to 80 PSI give or take.
The gauge measures both oil temp and oil pressure. You can toggle between 10 different colors, also have different colors for each separate readout.
Driving around tonight the oil temps hovered around 190-192 deg with 75 deg ambient. At 190 deg oil temp, pressure ranges from about 14 PSI at idle, 38 PSI at 1500 RPM, and between 48-53 PSI at 2000 RPM.
With the oil around 120 deg, I have about 50 PSI at idle, again at 190 deg and it's around 14 PSI.
Will be interesting to see how this 0W-40 & 15W-50 blend does with oil temps compared to a dedicated 5W-30.
I would also like to see if it's possible to change the idle speed to 650-700 RPM, and compare pressure results. Probably not needed, been doing well so far. Glad I did.it, wish I had done it sooner.
Comparison of factory gauge to the aftermarket.
