Where is this valve located?
*sigh* More stuff on the "parts needing replacement list" now....
It is right above the gas tank. There is a wire harness connected to it and a vent line on the other. Mounts in place with a plastic clip I believe.
:iagree:
Look at Swede. Either whoring while commuting or blowing off work to whore. One way or another, he truly is a :whore:
Reactions: swede
:goodpost:
:iagree: too.
Vroom
Stewzer55 said:
Whores
I think my thermostat is sticking open a little bit, last tank was under 14MPG but I think the fact that I have a short drive to work really kills that. Seriously, I live 5 miles away.
I could have a sticky fan clutch too, a couple weeks ago when it was -10* a hard run from 40-80 once it was warmed would make the coolant temp gauge drop 50*
Any idea what mpg you get on the interstate? I have a bad thermostat and can pull 18-22 outta my ass every trip on the interstate lol. Not sure what it gets on highway though.
Could eventually have a clogged cat from the engine trying to run hotter to compensate for the bad t-stat
Gut heeerrrrr!
Reactions: swede
Depends on where you live. If you live in California you really don't want a gutted cat. A lot of the shops check when you go thru smog / emissions check. And you don't want it to fail because it's costly and a pain in the ass.
:postcount: :whore:
They call me the cookie monster @ work, I have no idea why??
:postcount:
Yeah, I know. Just haven't gotten around to doing maintenance on her yet.
[emoji14]ostcount: :whore:
No emission checks here [emoji2]
Reactions: mcsteven
Good morning Swedish whore. Good night to the majority of the rest of you whores.
Reactions: swede
Good morning to you too Cali Whore
Whores
:iagree:
Swede is also a whore
Thanks :yes: but I have a long road ahead of me to catch up with you and your 6,500+ posts. So you are a lot bigger whore them me :whore:
I f...ing hate these f.....ing customer that come in the back door during lunch break because I locked the front door. How f....ing hard is it to understand, if the front door is locked and the sign say lunch break 12.00-13.00 leave me the fk alone. :hissyfit:
So I filled my truck up with gas this morning and right when the pump clicked off, i heard gas hitting the ground, looked under my truck and there was a small puddle of gasoline drivers side about midway of the transmission. I guess i will be putting her back up in the air and fixing a EVAP line somewhere.
morning whores!
HAPPY FKN FRIDAY :yes:
Lock the back door!
Sign on the back door "EMPLOYEES ONLY" (or whatever the Swedish version is, Endast anställda is what Google says)
:coffee:
Mourning
chh
