I'm posting this experience in case anyone else encounters similar conditions.
My 2002 Oldsmobile Bravada 4.2L AWD began giving me weird symptoms that weren't really pointing to anything specific. Yesterday it nearly stalled twice while idling out of my garage, no load, A/C off. Today, it gave me issues starting a couple of times and the gauges were erratic during one of the no-start fits. Then after a 30 or so mile round trip I parked it outside. When I tried to start the car to pull it in the garage the gauges began shaking and pointing at random readings. The speedometer would jump from 0 to 60 to 40 randomly. When I would twist the key to start it the cluster would shut down like it's supposed to. For the first few tries the starter would engage and immediately disengage. Then, that stopped as well. I would just get the erratic gauges with no starter activity. I tried to pull codes and my reader found none. Then I noticed the the SES light wasn't coming on at all. So I put my desulfinator on the battery and let it charge for several hours. When I tried starting the car again, the SES light came on dimly and briefly then went out and again, no starter activity. In desperation, I hooked my wife's car up to mine with jumper cables. At first, I had erratic gauges but after letting it charge for a few minutes the gauges settled down and the SES light came on. It then took only two tries to start the car.... my conclusion.... though my volt meter read a solid 12 volts the battery just didn't have enough amps to power the PCM and starter and was causing my gauges to freak out. I'll be putting in a brand new battery tomorrow.
