No power to one side of fuse 47
Jai_P
1
Ohio
Hello I have an 04 trailblazer 5 tranny codes popped up at the same time with diagnostic test. Did voltage test to fuse 47 and there only power to one side of fuse…. I have no idea where to go from here any help is appreciated! FYI codes didn’t pop up until key started getting stuck in ignition and needing to be manually released
Did you try replacing the fuse? If it blows again, could be a wiring short, either inside or outside the tranny, or a shorted solenoid. Also check the neutral safety switch wiring.
7,737
moscoreli
