NEED HELP No fuel
twerp473
6
Left work and stopped for coffee, got back in truck, and it won’t start. Order fuel pump of Amazon for $45, get in the tank and can’t attach plug(not sure why it looked the same). Get a new one from advance, comes w/adapter, put it in truck starts, yea! A few days later take it to the store, it won’t start. I put in dry gas (thinking there maybe water in it some how)won’t start, got out shook the truck as hard as I could and it starts. A week later, neighbor takes it to work says it ran great, got in to come home and you guessed it, it won’t start! Checked all fuses and relays all good....
Any suggestions.... all help apprciated
I_Shoot_Back
116
Ponoka
check fuel pump relay. I've seen it where the relay is fine but the connectors in the fusebox that grab the legs of the relay being weak/loose. I remedy that by giving the relay legs a slight twitch so they wedge better into the connector in fusebox.
twerp473
6
Tried that, thanks...is there any possibility this could be a loose wire? It doesn’t sound right though with the amount it’s been driven.
8,084
It's kinda obvious, but what about fuel filter or fuel pump screen?
Gdub2306
