No DRL after quad diode mod?
Midnyteryder196
1,490
Osceola,Ia
Alright guys trying to figure this one out.. 05 tb ls i6. Did the quad diode mod at front fuse box and installed just like i had before on my own and numerous other gmt.. And it didnt work. Low beams didnt come on, and highs were dim. Took the diode out and lows and highs work like they are supposed to with the switch, but now no drl, or flash with lock/unlock.. How can this be if drl and the flash is controlled by the bcm? Is there a fuse or something im missing?
14,950
Did you try flipping the connections? The diode could have been in the wrong direction.
Midnyteryder196
1,490
Osceola,Ia
well i guess this thread can be deleted now, after starting truck after having diode out for a lil while everything works like its supposed to..
Reactions: djthumper
Midnyteryder196
1,490
Osceola,Ia
negative, he didnt want to install it after the issue he had i guess.. i dont know if he didnt have it hooked up right or what the deal was.. I tested it before i sent it out and everything worked as it was supposed to.
Midnyteryder196
1,490
Osceola,Ia
Oh ok. Asking for a customer. I thought you were doing the mod yourself to the TB. Sounds like operator error to me :yes:
Mine has been done for quite a while and i even did a guy local to me without issues.. So i agree must have been operator error.. Lol
10,687
:iagree: Sounds like the diode was going in the wrong direction, and connected from the low beam relay coil, to the high beam relay feed to the bulbs.
The DRLs being on, is why the high beams were dim maybe? He may try again if he realizes how simple of a mistake it was.
Midnyteryder196
1,490
Osceola,Ia
he supposedly wired it up as instructed. i couldn't get him to send pics, all he said was it was how i told him to install it. So im not for sure exactly which pins on relay it was running. i got the impression that after the whole drl not working that he doesnt really want to mess with it anymore..
dmanns67
32,979
Yeah I knew you had the diode mod done for quite some time, but thought you personally were installing it on someone else's TB.
If he wouldn't send pics for additional help, sounds like he probably was not sure what he was doing to begin with. Another one of those FB only researchers :no:
You guys talking about at the fuse box or at the BCM? I did mine at the BCM, no issues here.
Fishermandude
