New Rubber, 265/70/17's
mikeinDE
855
Boog2006
151
Looks great! Now I'm curious about running no spacers with my 2.5" and new springs....hmmmm
mikeinDE
855
Thanks man, I am surprised how well they fit!
mikeinDE
855
ksimm92 said:
looks great!:thumbsup:
Thanks, I was worried about keeping the white letters out....
ksimm92
166
yeah, i think it depends on the overall look of the vehicle it's on. The white letters out on your truck looks sweet!
mikeinDE
855
:thumbsup: thanks, that's what's up!!! :cool:
ksimm92
166
I just thought I would share, that even if you were unsure it's better than having 2 white letters and 2 without! :crazy::rotfl: ... I bought the tires/rims like that used, but i have since had the white letters flipped so they are all the same now. :wootwoot:
mikeinDE
855
oh wow, that is a :crazy: setup. did you flip the whites out or in?
Opeth
177
My 265/70-17's rubbed like a mofo.... But I'm also running the 1.5" spacer. Couldn't find a set of wheels I like in the 6x5 pattern. I still have more trimming to do, could also be they are a M/T tire too.
Looks good!
mikeinDE
855
Looks good!
Thanks! I was worried about the upper ball joint clearance, but I can still fit a finger thru in there, as you can see in the picture above.
And at full turn, I checked how it looked versus the fender liner, the result is a bit less than a finger but it does clear......
At full turn...toss it in reverse and see if they rub. Seemed to be when mine used to rub the worst.
DARKASS04EXT
193
whats the offset of those wheels you have on it. Im curious if your offset is different than stock or not. That may change how they fit with others trying that size.
looking good!
gboos
34
Maybe the offset from the wheels is the problem and difference ....
Opeth
177
25mm offset. Just going to keep cutting where I see it rubbing. Most of it happens while in reverse like Hardtrailz said his was.
DARKASS04EXT
193
A local tire shop has a set of 4- General Grabber AT2 265/70/17, that he swears will fit my stock TB. I call BS after looking at that pic of the 265/65 on stock wheel.
Guess i gotta keep looking. :frown:
mikeinDE
855
Trey, I am not sure how to find out the offset of the wheels?
But they are American Racing "Marin"s if that helps....
Footnote, I still haven't tried the "full turn/in reverse" rub test....Keep forgetting.....:crazy:
Tcwest38
