I did some research before buying the 2002 TB with 70k on it. One owner and no dents and no leaks except the water pump that I expected when I first looked under hood and saw a low coolant reservoir. I had read up about cylinder sleeves problems but this rig is out of the VIN window for that problem. Am aware of a possible valve seat problem down the road and what causes that. Was aware of the fan clutch problem but had been replaced 35k ago and was aware of the water pump weakness and sure enough does leak. Am replacing the water pump within the next 3-4 days and will do thermostat/water outlet at same time. I am aware of the short cut to get the fan shroud/fan/fan clutch out easier. I am also aware of the typical "sewing machine" noise from the valve train. I am doing a full synthetic oil change and Wix XP filter when I do the water pump. I ran shops for 35+ years and love Wix, so don't try to talk me out of them, if you even planned on it. I am old, 70 on the 24th, and set in my ways.
Any other hints as to what to expect from this rig? Thanks in advance for any help.
By the way, I also own a 2005 Tahoe Z71 and am very active on the Tahoe/Yukon Forum.
I do appreciate any help and info but will be away for a bit. Going to coast today.
