Stud snaps clean off. Same place each time. Everything suspension wise is fine. There is nothing causing more weight to be on that endlink. And I've searched other threads, but its usually replace and stuff. Wondering if anyone actually fixed the issue.Snaps in what sense? The ball is coming out of the socket of the joint? Or the stud snaps/breaks?
First I've heard of this issue but I'm thinking that it may be working itself loose and/or the hole is egged out. I had to weld some washers to the bar and A-arm mounting point as they would get loose and knock.
Maybe change the brand and make sure it's really tight, more than spec, and use red Loctite.
