- Nov 18, 2011
- 49,665
I have some rust on the inside of my doors that I am going to use Chassis Saver Rust Convertor on and one spot has shown up on the outer door edge as well. Also have a couple minor dings in lower driver door and tons of rock chips and scratches from wheeling. So I got a gallon of Black Monstaliner as well to do the outside of the doors. Problem is I am not sure how I want to do it or now that I removed the side moldings, if I even want to cause I like how it looks and I could possibly just sand and touch up the outer lil spot. Size of 1/2 a quarter on bottm of door.
So my options are...
Leave it as is and just do inner doors and touch up the lil spot on outside...
![](http://i477.photobucket.com/albums/rr131/hardtrailz400/sideview_zpsc55605f1.jpg)
Do the bottom 5-6 inches to where the curve smoothes out..(sorry for crappy MS paint)
![](http://i477.photobucket.com/albums/rr131/hardtrailz400/test_zpse2367122.jpg)
Do up to level with the front and rear bumpers for a basically straight line around the truck...(older photoshop)
![](http://i477.photobucket.com/albums/rr131/hardtrailz400/shop2_zps8900269d.jpg)
Do the lower doors and over the fender flares as well...(Older photoshop)
![](http://i477.photobucket.com/albums/rr131/hardtrailz400/shop1_zps64f031c3.jpg)
Any thoughts from people? I will likely try an initial test with some plasti-dip, but the MonstaLiner is a gloss finish and texture that matches my powdercoated bumpers. Plasti will be dull and flat, but is removable.
