Anyone have ideas on how to remove this nasty pitting on my rims? The rims I was told are aluminium. They as you can see are just the stock rims.
DJones said:What causes that is the clear coat coming off. Sand paper will clean up the oxidation, then you should put more clear over it. It would work better if you remove the weights before fixing.
Exactly, Thats all the SS has on it no outside weights. Definitely going to take some elbow grease on those bad boys.bigytwotone said:these are what the weights look like View attachment 4169
:banghead:Cable810 said:bigytwotone The link to the weightsaver dosn't work... I hate to ask this but where are the wheel weights?
Thanks Hardtrailz I'm hoping tomorrow will be a nice 40 degree day that I can get this done.
Another question when I get this cleened up I'm debating on whether to paint the rims or not. If I paint them I want to go black but what how will it look on the Medium Green Metallic??
Cable810 said:So if I'm to remove the weights It will no affect? Dang Its 40 outNow I have a project!!
HARDTRAILZ said:You will need your tires re-balanced...
Sparky said:Hm I didn't even think much of those weights. I thought they were a little ugly on the outside edge but no biggie I thought. I should probably have them switched to stick on weights.
.... Rubberman said:Can;t you get them to add the weights onthe back side of the rim instead?
