- Dec 6, 2011
- 782
I am chasing a P0016 that only comes on after a very cold start. (Usually -16C or below.) The engine runs normally, and if I shut it off and restart, it does not display any symptom of a lost cam position. It seems to only last a few minutes. If I erase the code using my BlueDriver, it will not come on again until the next deep cold start.
I am suspicious of a ground issue or perhaps an oil issue.
I replaced the CPS and the CPAS. (AC Delco) My old CPAS was only three years old, and came out very clean and no oil in the connector, but replaced it anyway. Oil is 5W-30 and fresh. No signs of sludge. Performance is as normal as the day I got it.
I have a multimeter but no Tech2. I haven't started looking at the CPS connector quite yet as it seemed very sound when I put in the new CPS. But based on the fact that a CPS connector is a common aftermarket part and based on having to replace my blower fan motor connector that SEEMED good (but was fried inside) I am suspecting the connector or perhaps a ground farther down the harness. The reason I suspect a ground is because grounds have a tendency to not connect well on very cold days. (Shrinkage.)
The reason I am coming here first is that there are no other codes; I don't know where the ground comes from anyway, and if a ground was at fault, would it not throw a code for other components? I am also not sure of the difference between P0016 and P0341.
It also seems to have started after my last oil change. I went from a 5W-30 Mobil 1 oil to a MotoMaster (Shell) Synthetic 5W-30 High Mileage oil. (I have just over 210,000 KM)
If the oil is suspect, I have no problem draining and refilling if needed. Ideas?
