Hmmm...
May not be the MAF involved in this particular instance...
But depending upon your Mileage (If VERY High) and your Historical Misfire Counts with any P03XX Codes... (P0300 to P0301-P0306) then You might have a Clogged
(Poisoned) CAT causing Back Pressure and Killing Power whenever driving at Higher RPM and under Higher Engine Loads while at Highway Speeds...
One EZ Test for this Issue is... With the Vehicle PARKED AND WHEELS CHOCKED... ENGINE OFF AND PARKING BRAKE SET FOR ANY INCLINES...
(1) Lay Down a Large Piece of Clean Cardboard under the Passenger Side of the SUV.
(2) Recline upon it and after getting comfortable... Take a "Dead Blow" Hammer and VERY GENTLY
*Tap-Tap-Tap* on the underside of the S/S CAT CAN and Listen for the sound of
"Coins being dropped into a Ceramic Bowl" ...sort of sound.
(3) If you can hear any such *Tinkling Re-Bound Sounds*...then it means that the Rare Earth Impregnated Ceramic Honeycomb Insert might have Fractured and Fallen down inside of the CAT CAN and thus, render an obstruction to any High Flowing Exhaust Stream... causing a Back Pressure event.
Performing Other Tests is the right approach... Such as doing a (Relative) Non-Invasive Compression Test using an Oscilloscope to read the Amperage Draw during the Short 10-15 Seconds of Starter Activation while using an AMP Clamp fitted around the Positive Battery Cable
(The Negative Cable will also work by flipping the AMP Clamp Over). This approach can easily reveal LOW Amperage Draw changes on any Cylinders with LOW Compression.
This is the Least Invasive of the Two Compression Test Methods
(versus a much more Hands On "In-Cylinder" Compression Test) but it does require an inexpensive Oscilloscope connected to your Laptop Computer using FREE PICO-Scope Automotive Software to view the rising/falling Amperage Draws per Cylinder.
LOW Compression always produces LOW Power during Combustion Events.
Having Broken or Worn Out Compression Rings and Ovaled-Out Cylinder Walls or Leaking Valves will also produce LOW Compression Events as well. These issues are caused "Mechanically" and thus "Marvel Mystery Oil" and other such solutions will not make any lasting improvement and so, the corrective action might require extensive internal repairs.
If this turns out to be the case... Swapping in another Low Mileage 4.2L Engine of Like Vintage
(As Rare as Hen's Teeth) is preferred to attempting the R&R of the GMT360 Atlas Engine (17) Bolt On Head via frequently
*Snapping Off* Head Bolts or any secondary repairs while the Old Motor is still located in the Engine Bay. Instead... Choosing the Low Mileage Replacement Motor Route is a Much Better Long Term Solution.
Even though the VOP (Video Original Poster) below is a "Brit" and thus, may not be working on North American GM Products... Nonetheless ..
. He absolutely knows his *Stuff* around Automotive Diagnostics... especially when Demonstrating the Inexpensive PICO-Scope Model# 2204A unit married to the Hantek Model# CC-650 AMP Clamp while performing tests like these for Relative Compression.
Note that for a Visual, Identity Reference, he chooses to pick up the Ignition Coil Signal from the #1 Cylinder... but protects the PICO-Scope on the #2 Channel-B by first installing a Hantek Model# HT201 ... a 20:1 Voltage Attenuator BNC Unit ...and he explains WHY this is required for High Voltage Readings during this Test:
For More On Site GMT Nation
"Oscilloscope Dope" In-Sight ...Visit THIS Link:
You don't need a Huge Bag of Coins in order to obtain and use an Oscilloscope for performing In-Depth Wave Form Analysis in Automotive Applications on everything from Problematic Electronic Fuel Injection to obtaining accurate Compression Tests to Diagnose Internal Engine Conditions. HANTEK...
gmtnation.com
