looking for pics of lifted envoys
psycho91
62
As the title states I would like to see pics of your lifted envoys and trailblazers, specs would be great with the pics as well
10,685
Voymom
2,523
Look up Regulator...
He has one badass and sexy off roading Envoy's I have ever seen!!!
But then again I am only slightly partial to Envoy's :biggrin:
Voymom
2,523
silvernclean said:
Regs voy and my voy
Regs voy while getting front bumper fabbed
You know, looking at the picture of your's and Matt's Envoy's....It's amazing how different and personalized they are. I always thought an Envoy is an Envoy is an Envoy....but looking at that picture it's amazing how different the 2 are.
Sorry had a girly moment there :biggrin:
Voymom
2,523
psycho91 said:
How much lift is on it and what size tires
I think, and someone correct me if I'm wrong. It's a 3" body and a 3" suspension lift. Tire size..I couldn't tell you lol
If you read available build threads most of them list what size tires and what type tires they have with their lifts.
State of the art (except for three trucks with solid axle swaps) is 3" body lift, 3" front strut spacer lift, about 4" in the rear with a combination of spacers, Tahoe/Avalanche Z71 springs and Airlift1000 bags.
And state of the art for tires is 35" (6" larger than stock, which gives you 3" additional ground clearance) BUT 35"s tend to break gears, CV shafts and splined disconnects and are difficult to wheel with because of rubbing. 33"s (with 2" additional ground clearance) are the usual target tire size for the typical aggressive offroading.
And you can spend more on bumpers, underbody armor, and recovery gear than you will on lift, wheels, and tires. :eek:
jrSS
He has 33" tires 2.5 suspension and a body lift. he has not upgraded to the 3" body yet.
jrSS
jham said:
I could've swore he has the 3 inch body lift :confused:
He does. He has the 3" body lift but not the 3" suspension. I just called him. Lol. I am an idiot.
Regulator
2,496
Sorry, I have been away for a few days. Here are some pictures as requested. The Duke has MarkMC's 2.5" suspension lift and 3" body lift, 87 rated springs in front and z71 springs in the rear. I have the full compliment of armor from BartonMD including a beautiful new bumper. More information can be found on my profile and garage pages.
and the new bumper:
psycho91
62
Did you have to upgrade anything cause of so much lift or did you just put the lift and tires on and go, also what size tires you running
Regulator said:
...More information can be found on my profile and garage pages....
psycho91 said:
...what size tires you running
To view people's profiles, click on their name -> View Profile then hit the "About Me" tab.
But in general, when you add the lift components, typically we also flip the upper control arms to improve ball joint angles, change shocks, change to aftermarket CV shafts to get the benefit of more flexible boots that tend to leak less after the lift (or clamp the OEM ones well using 4" hose clamps) and install underbody armor like a stell or aluminum oil pan skid plate to protect the soft underbelly of the trucks.
My stock boots were far better and the aftermarket ones I had to clamp and are the ones that seem to tear or get holes easier. The last replacement I got came with stock boots and was a reman. It has been great. If they could use the factory material but have the a little more flexy it would be best.
psycho91
62
Well I wont be offroading it, will I still need to replace all that stuff, also I'm only looking to do a 2in body and 2 in suspension lift, what's the Max tire size I could run with 4in of lift
psycho91 said:
How come no one runs 31x10.5 tires
Typically a size for 15 inch wheels. Only certain wheels will work. My research on what works is out there for your reading.
fishguy1123
310
As the great Roadie would have asked... state your intentions/expectations. These guys can give you every detail you could ever ask for on a 360! A lot of hard work and trial and error went into what they know and have done with them. I personally have never met one of them, but I will say that if they told me the sky was red and that meant to change something on my truck.... I'd DO IT. If you just want the look mostly they can help. If you need more, they CAN help. They put alot into helping us and I hope you can see that in your searching through the nation.
Voymom
2,523
You could always do the mall crawl look if you don't plan to actually off road in it. Or keep it stock with just bigger more aggressive tires. I plan on doing this, as my truck is both a DD and I use it to spot in, which sometimes requires me to go off-roading.
I don't plan on doing much of a lift. I plan on leveling the ass end and putting more aggressive tires on it, but not aggressive enough to need to really cut anything. I already have Bilstein HD shocks but I want to upgrade my springs and get newer shocks as mine are a bit nasty and slightly worn. So you can get the off-road appearance without actually going full blown off-road modifications.
These guys put a lot of work and a lot of money into their trucks to lift them, but they do it so they can actually go off-roading. Why spend the $$$ if it's not going to be used for what it's for? The look is nice yes I will agree with that, but not really economical to be used as a daily driver. Just my 2 cents!
psycho91
62
You hit the nail on the head, a mall Crawler is pretty much what I'm looking for, I figured I would raise it 2 inches or level it out with some bigger meats on it, is it possible to level the front out with the back seeing as its higher in the back, I think it would work better that way with the bigger tires, also now that we know I just want the look, I would like to know yalls opinions on this matter
14,950
Most of us off-roaders run our rigs as DDs as well as actually taking them off-road on when we get the chance. If you are going to be a mall crawler then just go with the nerf bars and the bigger tires. Unless you have a definite mission that requires the lift, springs and shocks. And you are willing to lose a significant amount to your gas mileage, we have had enough people complain about how much they wasted on the lift and lost way too much in gas mileage. Even just leveling your ride can decrease your mileage.
Regulator
2,496
As The Roadie said, I flipped my upper control arms, upgraded my half shafts, and have replaced ball joints and sway bar links. I also had to cut 3 inches of my fender to fit the tires with out any rubbing. It is a serious comment.
Just go with MarkMC's 2.5" suspension lift and an All Terrain set of 31's. Expect to see a drop in MPG, but it shouldn't be to significant.
psycho91
62
Will I have to upgrade anything with the 2.5 lift, will it level it out or will the front still sit lower, can I get a link to the lift
Spoonfeed much:rotfl:
You have been given links to various resources in posts 2 and 8. Since very vehicle is slightly different ONLY YOU can tell if 2.5" will level YOUR TRUCK out if you put no lift in the back. Surely you own a tape measure. :wink:
moscoreli
