Hi , I just replaced the rack and pinion in my 02 Tb ltz. I got it from Detroit axel.after I put the steering lines in it is leaking really bad is there some kind of seal that goes on the lines where they go in?
I did see those. but wasn't sure. in the picture they looked like the plastic shipping caps I had to take off the new rack. I will have to order them.Yes there is they are actually rubber cups. Once you put them onto the rack you have to press the lines in and once the bolt is tightened down your good to go. Hold a second as I look up the part # and link to rockauto for them.
Edit: here's a srceen shot of the ones I got there the gates brand.View attachment 93302
I was so happy to be done replacing the steering rack I think I would have lost it if it would have leaked.
Brutal!I already installed it twice the 1st had 16 mm threads. I realized I had the wrong one when I went to put the ball joint in. I pulled it out and ordered the correct one with 14mm threads. Now I have to pull it again.
